Page 1 of 14
				Pcx Yuminashi Chainsaw 164!
				Posted: Fri May 02, 2014 3:32 am
				by Pcxdemon
				New project about to start,hopefully bit more poke too...
				Re: Yuminashi Pcx 164cc
				Posted: Fri May 02, 2014 7:04 am
				by nribeiro
				Just awsome!!!
Could you tell me if the scooter with a big bore kit will over heat? Some one told me that there is 4 guys in Portugal with big bore on their PCX 125 and all of them had to stop the scooter cause the engine temp light switched on! I'm afraid of that if I go on with this big bore. That's why he told me the safest one will be big bore of 150.
				Posted: Fri May 02, 2014 8:19 am
				by Pcxdemon
				nribeiro wrote:Just awsome!!!
Thats not what i like to hear nribeiro
 ...Depends on many things id say , lets say Takegawa is 169cc and its a good kit as it come from the shop
  but it wont like adding more to it like a big throttle body and other mods that will increase significant power or it most likely will blow head gaskets
 . Yuminashi is little smaller in size than Takegawa so head gasket will be bit wider and more safer so if installed properly shouldn't give any problems,I Hope!
				Posted: Fri May 02, 2014 8:53 am
				by nribeiro
				But you already have one with big bode right? Or I'm confused?
				Posted: Fri May 02, 2014 9:07 am
				by chainsaw
				what are you doing head-wise? presume you are double springing or are you already double sprung?
          I will be picking up a 175 kit amongst other goodies in a few days and have many questions for reggy if i get to see him.  luckily I have already convinced my girlfriend that picking up scooter parts in a foreign country following a two hour train ride to an ancient Siam city (Ayutthaya) is perfectly normal in these parts.
				Posted: Sat May 03, 2014 6:04 am
				by Pcxdemon
				chainsaw wrote:what are you doing head-wise? presume you are double springing or are you already double sprung?
I'm double sprung already and reacently head's been cleaned up and valves lapped.
I think you will be first with 175kit with 150 head, that'll be interesting..make sure you get the 31mm throttle with it.
				Posted: Sat May 03, 2014 6:29 am
				by nribeiro
				Injector,31mm throttle body, kn filter and exhaust should increase performance on stock 125 engine?
Or it cant handle this?
I'm not too interested for now to go for the big bore. Or it is better change tha valves only to get some power for now?
				Posted: Sun May 04, 2014 1:55 am
				by Pcxdemon
				Yumi is all in, took us 2 cups of tea and some 3 hours putting it in together.We weren't rushing. The Yumi camshaft seems interesting,It has an overlap,seems like a long duration intake, valve adjustment was way out from the takegawa setting when we installed yumi cam.
Yumi uses single metal gasket where Takegawa is 3 layered metal gasket so that's where yumi gets higher compression at 12.3 vs 11.2...
Next couple of days ill change fresh oil and put it all together,then ill fill the coolant in and fire it up. Fingers cross itll be ok..
				Posted: Sun May 04, 2014 2:00 am
				by nribeiro
				Hope it will work OK!
				Posted: Sun May 04, 2014 3:07 am
				by pcx125
				Hi Pcxdemon
I knew you're very experienced and play around a lots with PCX125/150 and now on the way to a new project with Yumi .
Do you think INERTIA POWER BOOSTER SET YUMINASHI will help with the acceleration on PCX125 ? and if I need to upgrade vario set in the near further should I go alone with Yumi or Malossi Multivar 2000 set ?
				Posted: Sun May 04, 2014 4:23 am
				by Pcxdemon
				pcx125 wrote:Hi Pcxdemon
Ive got no experience with either of those so cant really comment. Someone else on here has a yuminashi inertia and a malossi vario,maybe they can chim in...
				Posted: Mon May 05, 2014 1:05 am
				by mikelx5
				the inertia booster you would need a bbk for it to help. my 150(stock motor with pipe) was slower all around but head wind didnt slow me as much so i believe it just helps with maintaining a higher speed. but some word of caution if u decide to install it make sure the fan is not in contact with radiator, mine was. no idea on the malossi vario tho im using the yumi and love it
				Posted: Thu May 08, 2014 7:21 am
				by Pcxdemon
				First start up tonight,she works
 !! Tomorrow tupperware will go on and a little test ride. So far so good....
				Posted: Sat May 10, 2014 8:07 pm
				by Pcxdemon
				Ok, after few days of riding and testing I have to say I'm very impressed with Yuminashi kit combo. It has really good power, acelaration is awesome,mid and top range is vicious. That camshaft profile is really pronounced vs takegawa one,Yuminashi is really extreme and awesome. It gave a Harley run for its money up to 100kmh of the lights...
Choice is clear, Yuminashi all the way.
The bad things now: I'm using just a bigger injector to fuel the kit and it's more than enough however I'm hoping that the ecu is still learning it's new parameters but when cold it's running quite rich on idle when cold to a point it may stall due to too much fuel being injected. I've had a little play with idle control valve  to adjust the amount of air in the idle and that made a small difference but hopefully the computer will adjust soon enough and she'll be fine.
				Posted: Sat May 10, 2014 8:51 pm
				by nribeiro
				Awsome!!
Just a question about the camshaft. It can be installed on stock 125 bore with the Yumi valve springs only? Or I have to buy also the big bore?
Another question is due to a smell of gazoline I note in mine when starting cold. I may have a small conic filter and that's why.
Keep going with this extreme PCX tuning!!!
				Posted: Sat May 10, 2014 9:19 pm
				by Pcxdemon
				nribeiro wrote:Awsome!!
I'm not sure, best is to send an email to Yuminashi for that question. I remember when mine was still 125, I used takegawa cam and exhaust and it was a decent boost but yumi cam is really hot so I'm not sure how it may be on stock 125.
Talk to yumi, Reggy will guide you in the right direction.
				Posted: Mon May 12, 2014 12:41 am
				by chainsaw
				you can use the cam with stock bore but you will need more fuelling ie throttle body/injector, also you will have probs with camshaft touching the rockers.The rockers can be ground back or yuminashi have rockers to suit. I picked up some parts from reggy a few days ago and bombarded him with questions
  I bought most of the parts i needed off him bar the big bore kit and crankshaft (to suit 150). he is currently developing a new piston kit for the 150 as he wants it to be lighter than the one available now. He said it should be ready in a couple of months and i will get the rest of the parts then. Now i just have to find a decent engine builder in perth
				Posted: Mon May 12, 2014 1:46 am
				by Mgalutia88
				So Vlad, takegawa ficon2 with 170cc bbk with cam for 15hp for $400 or yuminashi 175cc and rocker arms, cam, valve springs for $500?
				Posted: Mon May 12, 2014 2:42 am
				by Pcxdemon
				Mgalutia88 wrote:So Vlad, takegawa ficon2 with 170cc bbk with cam for 15hp for $400 or yuminashi 175cc and rocker arms, cam, valve springs for $500?
Yuminashi all the way  Mike, my Pcx is like an angry chainsaw right now. Itll blow socks of an 300cc scooter to weeds..
				Posted: Mon May 12, 2014 2:43 pm
				by nribeiro
				Thanks for the reply.
After the torque spring change the PCX turned a litle demon!!! And yesterday I did a small mod on the JCosta vario. I modified the sliders so the total could be 90 grams. What a diference!!! If I'm at 40kph and accelerate just a bit what a boost!!! The engine rev's fast and powerfull!
I'm still not able to reach 120kph on flats but almost there and I'm still thinking if I'm not beeing unfair with her since in Lisbon I don't know why it's beeing windy more than usual!!! Even so my PCX is more powerfull than stock and can keep good speed with lot's of wind.
About upgrade mine... Probably I'll upgrade just the valves spring since the stock ones start to float before the electronic limiter kicks in and I think will help a lot. I want cheap mod's for the engine first.
