Rear fender removal
- Joemag22
Rear fender removal
Hey everyone, I was looking around for a rear fender removal thread and couldn't find one. Does anyone have some info regarding the rear lighting kits? I found some on the World Wide Web like this:
http://www.ebay.com/itm/HONDA-PCX-125-1 ... 1141818344
Ideally I want to remove the fender, license plate holder, and turn signals. I wanted to install some flush mount turn signals similar to maddiedog (sorry to be similar, but it looks so clean) and deal with the LP mounting somehow.
I'm just unsure if there are some hidden clips or brackets that need to be addressed before removal or I ruin it forever...
Current: 2011 Honda PCX125 (j.costa vario and j.costa exhaust)
Past: 2008 Honda Met (Dayton drag vario, CDI box, spark plug, kn filter, and a cup holder)
** NOR-CAL / East Bay Met Set SC **
- chainsaw
- Year: 2013 150esp
- Color: white/carbon
Re: Rear fender removal
you will need to remove pretty much all the rear bodywork, seat included. not hard but a bit fiddly and time consuming.
http://www.sportbikelites.com/HONDA-PCX ... oter-1.htm these are one of the tidiest conversions i've seen around especially for the ugly american spec lights
ive done that actual kit looks so much better even has the liscence plate light only thing im not sure on becuase i changed out my flasher earlier for an led one so u might need to
									DISOBEDIENCE CREW
						- Joemag22
Thanks chainsaw and mike, I think I can handle all the disassembly to get to the fender removal.
Since the US pcx is the only bike with these protruding blinkers (or winkers) is it possible to get the EU model rear end?
Also in this link.... is this the EU rear end or is it some other set up?
http://www.motorkit.com/en/accessoires/ ... a-pcx.html
Thanks
Thanks
This seems to be a cover tailored to the EU rear end, indeed. In the stock EU setup, these covers are black plasticJoemag22 wrote:Also in this link.... is this the EU rear end or is it some other set up?
- Joemag22
I really like the look of the EU set up. Are these rear fenders interchangeable? Or are the connections different?
Not quite interchangeable we are missing some brackets to imtall properly had a friend with a 125 we couldnt mount the signals at all
									DISOBEDIENCE CREW
??mikelx5 wrote:Not quite interchangeable we are missing some brackets to imtall properly had a friend with a 125 we couldnt mount the signals at all
Its not a direct swap for american to the non signal stock version
									DISOBEDIENCE CREW
						- pcx888
- Color: pearl white
You gotta buy new rear tail light left and right.  New rear fender.  And new front body panel to get rid of front rabbet ears.
									2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Yorkie150 wrote:6 year old thread.......
Like a fine wine..
More like mouldy stilton.you you wrote:Yorkie150 wrote:6 year old thread.......
Like a fine wine..
