Tire Size?
Re: Tire Size?
With not having ridden a motorcyle/scooter before my PCX I didn't have much to compare it to. I didn't take notice of the tires that were on my PCX when I bought it used (15k kms - 9.3k mls), but I put less that 100 kms (60 mls) on it before I had the new tires installed (120/70 on the front and 140/70 on the back). As soon as I pulled away from the bike shop I could tell that there was a difference for the better. I hadn't thought about or anticipated a different feel to the ride, but I sure got one. It was a much more secure feeling.
Re: Tire Size?
the thinner tires, it feels nimble but at high speeds you can feel the grooves in the highway. The bigger and wider tires seems to feel, more solid grip to the road, next to no wobble felt on the highway from the rain grooves on the concrete. Takes few miles to get use to the new feel but it;s a good feeling.
Re: Tire Size?
I calculated the diameters of the tires and increase the height of the tire. Front wheel will fit 120/80 R14? Or increasing the height of 15mm is too much, will damage the fender? But, 15mm increase in height is very useful.
90/90 R14 D=517,6mm
120/70 R14 D=523,6mm, R+3mm
120/80 R14 D=547,6mm, R+15mm
100/90 R14 D=535,6mm
140/70 R14 D=551,6mm, R+8mm
90/90 R14 D=517,6mm
Re: Tire Size?
I was so impressed with the replacement City Grip rear tire on my wife's pcx that I had the new rear tire on my pcx swapped out for a City Grip. What a difference! Wow, I love that tire! Now I can corner much better than before. I think before you start thinking about wider tires, just put a City Grip on. You will feel the difference immediately.
Re: Tire Size?
Mel46 wrote:I was so impressed with the replacement City Grip rear tire on my wife's pcx that I had the new rear tire on my pcx swapped out for a City Grip. What a difference! Wow, I love that tire! Now I can corner much better than before. I think before you start thinking about wider tires, just put a City Grip on. You will feel the difference immediately.
In what way does it feel that much better? The stock tyres feel perfectly OK to me.
Re: Tire Size?
For me, with little prior riding experience, it is hard to describe the change but I guess the best way I can is that I felt like I had all of a sudden put sticky grip on the tires and I was connected to the road a lot more. Instead of feeling like I was floating on the road, I felt like I at attached to it, but not in a being dragged back kind of way.you you wrote:In what way does it feel that much better? The stock tyres feel perfectly OK to me.
That may not make any sense to many of you, but it is the best way that I can describe it. The tires that were on my PCX when I bought it had different levels of wear on them with the front being worn more than the rear, although neither one of them was worn excessively. I hadn't even thought about changing the feel of the ride when I put the City Grips on. I just liked the looks of the wider tires better so I swapped them out and got the pleasant surprise of a much better feeling ride.
- alx123
- Bangkok Rider
- Color: Fast White
Re: Tire Size?
I will revive this thread as I think this is very important.
If I understand the post here correctly, the biggest I can put is 140/70 at the rear. That might require slight modifications though.
I think the perfect fit without any modification is using 120 rear and 110 front.
Next question is, is there a specific marking where they say it's for the front use or rear tire?
Few years back, I can put any tire size on my bike without worrying whether it's for the rear or the front as we they don't have specific markings.
- alx123
- Bangkok Rider
- Color: Fast White
Re: Tire Size?
Ex. This 120 I want to use in my rear but there is a mark that says front...
Re: Tire Size?
You don't want a front tire on the rear nor do you want a rear on the front. It's all about the tread pattern
The way a motorbike tire grips the road when you brake, the way it manages water on a wet street... all in the tread pattern. They have distinct differences One could argue mounting it with the rotation arrow in the opposite direction but one would surely be wrong.... somehow.
- strike2.jpg (143.34 KiB) Viewed 988 times
- alx123
- Bangkok Rider
- Color: Fast White
Re: Tire Size?
@homie
Thank you. That made sense.
It seems that they are not making 120 sizes for the rear. (not sure)
I would love the look of that 140 on your pcx, but with a stock engine I don't think that's a good idea.
Re: Tire Size?
Yes I agree, with just the tires you would be the slowest PCX out there. Stay on your stock tires and maybe do this first. And yes the kit is good for 150's as wellalx123 wrote:@homie
https://www.youtube.com/watch?v=-NRc9g3Dasw
