Page 1 of 2
PCX 125 vs. 150 wich one better for tuning?
Posted: Thu Feb 06, 2014 4:13 pm
by Xedos9er
Hello,
I have to decide in the next few weeks wich scooter I buy. Of course if i stay stock, the PCX150 will be the better decision.
But since I want to go big bore, I can´t decide wich one is better.
There are not many people who run a PCX 150 with big bore. To stay street legal, i can´t run a open airfilter, so i have to stay with the stock airbox.
So what would you buy?
On the PCX150 I see some main advantages:
-can run up to 64 mm piston (187cc)
-bigger head (bigger intake and exhaust valves)
-longer gears (not sure about it)
-bigger throttle body (26 or 27mm?)
The plan was to get PCX150 and buy big bore kit to 187cc + takegawa camshaft. Maybe change pipe from Throttle body to Airbox and buy better filter.
Also i don´t know how fueling system will react to this modification. Do i need also a bigger injector on the pcx150 to run it properly? Dont want to buy a AFR gauge + imap to adjust the air fuel ration.
I´ve read that a big bore PCX125 runs perfectly fine with bigger injector without any changes to the ecu, but most people use the 31mm Throttle body and manyfold. Maybe the OEM Throttle Body from the pcx150 will be to small for the bigger injector?
Re: PCX 125 vs. 150 wich one better for tuning?
Posted: Thu Feb 06, 2014 4:41 pm
by Pcxdemon
Xedos9er wrote:Hello,
Get in touch with yuminashi about your dilemma, they've tuned both versions and will be able to offer good advice at which way to go about. I found them very honest when mining their brain for info..
By the way, where are you located?
Posted: Thu Feb 06, 2014 4:43 pm
by Xedos9er
Germany. I have to import the pcx150 from italy, which isn't a big deal.
I already wrote yuminashi, but didn't get an answer.
Posted: Thu Feb 06, 2014 5:16 pm
by Pcxdemon
Xedos9er wrote:Germany. I have to import the pcx150 from italy, which isn't a big deal.
Also try Roman at RZ Racing in Netherlands. He is connected with Yuminashi and has just finished two 175cc builds for someone i know. Has a lot of experience from the recent builds and some cool ideas,also sells all the parts you would want..
Posted: Thu Feb 06, 2014 5:24 pm
by Xedos9er
I'm in contact with him. It would be bice if someone Wirth a big bore pcx150 could post some results.
Posted: Fri Feb 07, 2014 12:08 am
by wingz
The PCX150 does have longer gearing than the PCX125. But not long enough.
I believe it is just one gear that you can replace with a stock gear from PCX150.
But you might be changing that gear with an aftermarket one anyway.
Depending on the performance you are looking for, you might get the results you want from a 150 without increasing engine capacity.
Posted: Fri Feb 07, 2014 4:06 am
by Xedos9er
I want best 0-100 times, so need more power. That means, there´s no way around a big bore kit
Top speed of 120 would be enough for me.
Posted: Fri Feb 07, 2014 5:08 am
by Mgalutia88
if its 0-100 your looking for go with Yuminashi parts as they are more racing oriented and a daytona variator.
Posted: Fri Feb 07, 2014 7:35 pm
by dasshreddar
I think it comes down to parts availability, 125 parts are easier to get than 150.(U.S. anyways)
BUT PLEASE get a 150 and do the big bore and post all about here PLEASE! I've been craving more power since day 1.
Posted: Sat Feb 08, 2014 3:39 am
by Mgalutia88
Where is that helix or forza swap we've been thinking about? Hell what about a yamaha morphous swap or trexx swap? Or new kawasaki 300 swap? Their new scoot?
Posted: Thu Feb 13, 2014 1:04 pm
by dem0nk1d
If a vendor makes a 4 valve head, it would increase performance marginally. it would be worth checking.
Posted: Thu Feb 13, 2014 2:31 pm
dem0nk1d wrote:If a vendor makes a 4 valve head, it would increase performance marginally. it would be worth checking.
Forget that. I'm boring mine out to 455 cubic inch
We've all thought of it, right!?
Posted: Thu Feb 13, 2014 5:07 pm
by Pcxdemon
you you wrote:dem0nk1d wrote:If a vendor makes a 4 valve head, it would increase performance marginally. it would be worth checking.
Nope,just you you has..
Posted: Thu Feb 13, 2014 11:46 pm
by wingz
I didn't expect you to discourage performance mods.
Posted: Fri Feb 14, 2014 1:35 am
by Mgalutia88
You you, Buick, Olds, or Pontiac?
Posted: Fri Feb 14, 2014 1:41 am
by Mgalutia88
I'm thinking GM LS aluminum block myself. A 5.3 turbo swap? Total weight would be around what 550lbs?
Posted: Fri Feb 14, 2014 9:33 am
Mgalutia88 wrote:You you, Buick, Olds, or Pontiac?
Oldsmobile toramado.
Posted: Fri Feb 14, 2014 10:34 am
by Mgalutia88
What about a '76 Cadillac eldorado 502 ci?
Posted: Sat Feb 15, 2014 3:00 am
Mgalutia88 wrote:What about a '76 Cadillac eldorado 502 ci?
Isn't that too big, will the seat still close?
Posted: Sat Feb 15, 2014 12:03 pm
by wingz
you could install a seat with a bigger hump
