Page 1 of 2
				Something's not right
				Posted: Thu Oct 17, 2013 10:48 am
				by cessna151
				I bought my 150 new last year. When i got it everything was great. MPG was in the 90's and i was hitting the rev limiter at 72 MPH (speedo is dead on at all speeds according to GPS). Then the 600 mile mark came and i decided to have the dealer change the oil. I noticed immediately afterwards that i was hitting the rev limiter at 67 MPH and as time went on i noticed MPG had slipped to the low 80s. At some point i realized the dealer used the wrong oil (GN4 10w40). At the 5,000 mile mark i changed the oil to the correct oil (HP4M 10w30) hoping this would solve the problem. At the 10,000 mile mark nothing had improved so i changed the oil again and replaced the drive belt, spark plug, and air filter. I have only filled up 3 times since the service but so far MPG after the service is in the upper 70s and i'm hitting the rev limiter at 69 MPH.
This bike should be getting MPGs in the 90s and i should be hitting the rev limiter at 72 MPH with the new belt. What could the dealer possibly have done to my bike?  Both wheels turn freely, brakes not dragging. New oil, plug, belt, and air filter. What else can i do to diagnose the problem?
				Re: Something's not right
				Posted: Thu Oct 17, 2013 11:02 am
				by ~Cheap_Ride~
				I think you have done what I would have checked for anyway.  If its of any help I feel like I am experiencing the same things.  Last week on the hwy I was only able to reach 66 on a flat stretch of road.  I dont keep track of fuel mileage but the numbers of miles on my trip odometer seem to be down when I start flashing from what I remember them to be brand new.
It has gotten cold here in SD with lows in the mornings close to freezing and highs in the 40's.  That could be part of the problem.
				Posted: Thu Oct 17, 2013 11:16 am
				Rear tyre wear, type, size, actual circumference compared to a new OEM IRC?
Any wear on the pulleys?
Condition of rollers and ramps?
Tried disconnecting the battery to reset the electronic brain?
				Posted: Thu Oct 17, 2013 11:17 am
				by dasshreddar
				change your drive oil... did the dealer change that too?(heavier weight maybe?)
have you modded the cvt? 72 seems too fast if stock, is your current speed gps verified 69mph?
				Posted: Thu Oct 17, 2013 11:25 am
				by jkhawaii
				valve adjustment gone wrong?
				Posted: Thu Oct 17, 2013 1:29 pm
				by DAB
				Is there a software update on 600 miles? Over the years I have known people to have lower mpg after dealer updates.(Motorcycles, mainly Triumphs)
				Posted: Thu Oct 17, 2013 3:02 pm
				cessna151 wrote:I bought my 150 new last year. When i got it everything was great. MPG was in the 90's and i was hitting the rev limiter at 72 MPH (speedo is dead on at all speeds according to GPS). Then the 600 mile mark came and i decided to have the dealer change the oil. I noticed immediately afterwards that i was hitting the rev limiter at 67 MPH and as time went on i noticed MPG had slipped to the low 80s. At some point i realized the dealer used the wrong oil (GN4 10w40). At the 5,000 mile mark i changed the oil to the correct oil (HP4M 10w30) hoping this would solve the problem. At the 10,000 mile mark nothing had improved so i changed the oil again and replaced the drive belt, spark plug, and air filter. I have only filled up 3 times since the service but so far MPG after the service is in the upper 70s and i'm hitting the rev limiter at 69 MPH.
Not sure how changing the oil would affect a rev limiter
				Posted: Thu Oct 17, 2013 5:51 pm
				by Mgalutia88
				Just the thicker viscosity but 10-30 to 10-40 shouldn't make that massive of a difference. Check and look at your rollers in your variator. Did they get flat spots? If not there complain to the dealer. Let them look at it.
				Posted: Fri Oct 18, 2013 11:07 am
				by maddiedog
				10w40 is fine, it won't make much a difference.
I'd try resetting your ECU...
				Posted: Sat Oct 19, 2013 2:16 pm
				by cessna151
				you you wrote:Not sure how changing the oil would affect a rev limiter
Exactly. I think the dealer did something to my bike intentionally/unintentionally or something happened at about the same time. The receipt only shows an oil change. Who knows. I just want it fixed.
The bike is and has always been bone stock, no mods. I regularly check the speedo with GPS including the day i bought it. It has always been less than 1 mph off. I hit 72mph many times before the trouble. I remember reading somewhere that 71-72 mph is normal for a new 150.
I forgot to mention i checked the valves at 2,500 miles and they were in spec. I replaced the back tire at 5,000 miles and it's due again as is the front.
Thanks for suggesting the drive oil and disconnecting the battery. I will do both and will be changing both tires soon. I forgot to look at the rollers when i changed the belt so i'll do that if drive oil and ecu don't solve the problem. The pulleys looked fine though.
				Posted: Sat Oct 19, 2013 2:55 pm
				cessna151 wrote:you you wrote:Not sure how changing the oil would affect a rev limiter
I think I'd be looking at the rollers next too
				Posted: Sun Oct 20, 2013 10:45 am
				by sendler2112
				My PCX150 never came anywhere close to 72 mph at the redline on a flat, no wind, honest top speed run. Before any belt wear I was topped out at 66 mph. With some belt wear at 1500 miles I was starting to drop to 63 mph. With Dr.Pulley sliders I am back up to 69 mph which is either redline limited or power limited by the wind on different days. Your top speed is normal. Your fuel economy should be better unless you are big and catch a lot of wind. 90 mpgUS at 40 mph should be within reach for any PCX. 100 mpg at 50 mph if you tuck behind a Givi windscreen.
				Posted: Wed Oct 23, 2013 11:39 am
				by cessna151
				No, i was never able to hit the rev limiter on flat ground. I'm lucky to see 60 on flat ground. I was talking about going down hill to physically feel the bike bouncing off the rev limiter.
				Posted: Wed Oct 23, 2013 5:25 pm
				cessna151 wrote:No, i was never able to hit the rev limiter on flat ground. I'm lucky to see 60 on flat ground. I was talking about going down hill to physically feel the bike bouncing off the rev limiter.
I have a slightly different experience. I don't feel any review limiter cutting in just the whole thing running out of steam at under 70mph max with the feeling that the belts and the transmission is at its limits
				Posted: Thu Oct 24, 2013 11:41 pm
				by Mgalutia88
				Check the rollers first and let us know how they look. That is most likely where your issue is.
				Posted: Fri Oct 25, 2013 4:47 am
				by sendler2112
				Edit. thought this was the thread about belt slipping.
				Posted: Fri Oct 25, 2013 9:05 am
				by Mgalutia88
				Belt slippage and damaged rollers can cause a similar effect. If the rollers get flat spotted or stuck the same effect can happen. Also you can shim the variator to eliminate slippage however that's not fixing the real issue, it's only a bandaid.
				Posted: Fri Oct 25, 2013 9:19 am
				by sendler2112
				Mgalutia88 wrote:shim the variator
The shim is only effective for eliminating a shudder on take off when using sliders which have made the low position of the belt too low to stay taught. Once the bike has any speed and the rollers move out from the park position, the shim does nothing further.
				Posted: Sat Oct 26, 2013 10:22 pm
				by rp150
				Is your air filter and intake system clean and not blocked.  Same thing for the exhaust side.  Is pipe ok,  Sounds stupid, but nothing dropped in the muffler?  Stupid crap does happens and no one wants to take the blame.
				Posted: Sat Oct 26, 2013 10:31 pm
				by rp150
				Is it possible that the parking brake is over adjusted?  I never use mine. But if a new tech thought he was doing you a favor and over adjusted the brake ?????
Just throwing it out.
