Hi everyone. Hope you are having a good day!
Quick summary - Key turned to On… Nothing. No sound. No lights. Absolutely nothing happens when I turn the key to on.
I had one of my bulbs die last week.
I replaced the bulb with a H4 60Watt (I was unaware the required wattage is 30Watts)
2 days later my second bulb goes, I jump to Halfords and grab another “200% brighter H4 60Watt bulb (still unaware of the 30Watt requirement.)
I replace the second bulb (Thanks guys for the previous forum on how to do that!)
Okay so both lights working, I set out for the day. Upon reaching a temporary red light(road works red light) I press the “Pass” button on the left hand side(UK only, this activates full beam)
Once the “Pass” button was pressed both headlights cut out
So now I’m back home checking the fuses, the Hi/Lo 10 AMP had been fried. Thankfully there was a spare 10 AMP fuse within the fuse box
Put the fresh fuse in, headlights back on! Woo!
It was late so tomorrow I was going to Halfords(shop) to get new bulbs that are the correct wattage.
Was driving my bike for about 30 minutes no problem and then I seen the bike cut out for a second (all dials reset/dashboard reset) then it happened 5 minutes later, then again.
By this point the ABS light is flashing and the dashboard is resetting every 10 seconds.
1 minute later the bike cuts out completely. (Pretty worries at this point)
Pull over to side. Start bike again.
Pulling away. Bike runs fine, steady revs etc etc.
As soon as I pressed the left brake the dashboard reset and the ABS started flashing again.
Okay - Thankfully by this point I’m 2 minutes from home. I’m able to drive home.
I park up, side stand on. Keys off.
Open right side(access to fuse box)
Check the ABS fuse - Okay
Check the main relay fuse - Okay
So i put the fuses back. Pop the cover on.
Turn the key to On…
