Replace headlight lamp
How do you get the connected to come off. I pull as hard as I can and it doesn’t work out. It’s seems locked or stuck
- Year: 2016 Forza 300
Re: Replace headlight lamp
My high beam died on bought sides at once - very strange, but it did. Low beam worked.
Took it to Honda to check fuse etc., but they said it's the bulbs...!
The guy replaced both and it worked. He put his hand under and took them out with ease, no need to look, just felt the cable, connector etc., I guess if done it before know what to do.
Sorry can't tell you how it is as I didn't do it. Check the part diagram here, it might help
https://pec.thaihonda.co.th/
Use Google translate
- ghmpm
- Color: red
I replaced headlight bulbs on two Goldwing GL1800s. Same thing, difficult to do but it can be done without disassembly using your hands. Not easy but can be done; Youtube videos help.
Glenn
2015 Honda Forza 300
2012 Honda Silver Wing
2005 Honda Goldwing Trike
