Hi all. I have a 2014 Forza 300.
While I was changing out the seat shock I lost it down in the void. I've looked and looked and can't find it. I'm trying to remove the seat storage but I'm not sure of the best approach. I did remove the seat and got the front part unlatched but I'm not sure the next approach to remove it fully. I'm thinking that I may need to pull the battery too. To the left front of the battery is a fuse block that needs to be moved somehow.
I'm thinking this may be easier to remove the tub rather than trying to take the bottom off.
Trying to remove the storage under seat
- ghmpm
- Color: red
Re: Trying to remove the storage under seat
I am not sure it is worth all the effort in this case. Replace the shock or use a stick; it would save much time and grief. In my opinion the battery is located in a terrible spot, I hate to replace it....
Good luck with whatever you decide.
Glenn
2015 Honda Forza 300
2012 Honda Silver Wing
2005 Honda Goldwing Trike
Had a similar problem and someone on here recommended using a "spring hatch holder". Works fine and easier install.
