No idea as to why headlights became dimmer
Posted: Sat Oct 29, 2022 2:40 pm
by 150pcxer
Hi all.
I realised recently that my front headlights have become dimmer than usual.
My bike is running on halogen HS5 35/30 headlight bulbs.
I have no idea what is the cause. I've brought the bike to the workshop and they checked
1) The battery. It was showing 14.6 volts on the multimeter when the engine was on.
2) The fuse. Doesn't look like it's blown.
I replaced with a new halogen bulb and the light is still dim.
In the picture with the "SLOW" marking, the light seems bright and whitish but in reality, it is actually dimmer and more yellowish.
The other picture is to show that the bulbs indeed emit a more yellowish tint of light.
Appreciate any help.
Thank you.
Re: No idea as to why headlights became dimmer
Posted: Tue Nov 01, 2022 7:22 am
by Ganglylamb
I have no idea what amps the fuse is rated as I have the LED version but: dimmer light and more yellow (lower CCT value) indicates to me that the current is being limited.
2 things you could do:
1) check voltage at light bulb - if you have a significant voltage drop compared to what the voltage is at the battery with the engine running then this indicates the resistance is too high somewhere between the battery and the light bulb socket
2) test each side of the connections to the light bulb socket for resistance
Perhaps there is some corrosion which is increasing the resistance or the power supply lines could even be 'pinched', effectively reducing diameter of the wire and as such also increase the resistance - which could become dangerous as this area of the cable will start to become quite hot with a DC current going through it.
Posted: Fri Nov 04, 2022 11:42 pm
by 150pcxer
Ganglylamb wrote: Tue Nov 01, 2022 7:22 am I have no idea what amps the fuse is rated as I have the LED version but: dimmer light and more yellow (lower CCT value) indicates to me that the current is being limited.
Hi.
Which is the set of wiring/cable that could be faulty?
URL 1 : https://www.bike-parts-honda.com/honda- ... 41/2/15471
is it 6 or 7?
or URL 2 : https://www.bike-parts-honda.com/honda- ... 01/2/15471
is it 4?
Thank you.
Posted: Sat Nov 05, 2022 7:25 am
by Ganglylamb
Honestly I have no idea - I have an LED version and even if I would have the non-LED version I would have to check myself on the bike. But anyhow here is the wiring diagram from the SM. Basically I would check every wire going to the headlight for resistance.
SM_22_3_wiring diagram 13 model.pdf
(2.64 MiB) Downloaded 1491 times
Posted: Wed Nov 09, 2022 1:39 am
by 150pcxer
Ganglylamb wrote: Sat Nov 05, 2022 7:25 am Honestly I have no idea - I have an LED version and even if I would have the non-LED version I would have to check myself on the bike. But anyhow here is the wiring diagram from the SM. Basically I would check every wire going to the headlight for resistance.
or could it be this?
https://bikerzbits.co.th/honda/pcx/pcx- ... generator/
