Using USB in glove box for gopro
Hi all. Decided im going to hard wire a gopro on the pcx 2022 125. I've bought a USB c to normal USB adaptor so can use the switched power supply in the glove box. Issue im having is getting the wire out off the glove box to the camera as the glove box is a good tight fit when closed. Any one have any good ideas on best way to do it or already done it. Dont mind cutting the glovebox but would like to keep it water proof to some degree
- 20221012_134651.jpg (315.9 KiB) Viewed 2009 times
Re: Using USB in glove box for gopro
Did a test ride using gopro battery and it was catching the screen and dash surround so moved it. Its now mounted and I drilled hole into top off glove box cover and used a cable grommet to keep it waterproof and prevent rubbing. Works well as can still open and close the glove box
- 20221015_121908.jpg (454.51 KiB) Viewed 2002 times
- 20221015_120646.jpg (346.62 KiB) Viewed 2002 times
mymitzi
Wondering...........does the image stabilization work well.......maybe, post a video ?? Thanks.
Hoping to get a few miles in tomorrow so I'll upload the footage for all to see. Hoping ut doesn't bounce or vibrate ti much
