My Dad use to say........Don't do as I do, do as I say. Any of you ever heard that one? Well.......anyway......I've been negligent.......checking my plug.
Last few days, the PCX didn't fire up [instantly] as it used to. Thought maybe it's past time I checked the valves?? [way past] [looked in my record
as to when the plug was last checked/replaced. [over 30K] Scooter was running so well.........never bothered with it. Should have......because it
was loose....... but the threads had so much carbon on them, almost couldn't back the plug out. Got the cleaned up/gapped spare plug and think
I got it back in there all the way but didn't want to do further damage so stopped forcing it. Fires up instantly again so pretty sure that was the
culprit. At this point............may leave well enough alone ...........afraid more damage will result. Don't do as I did............
check spark plug
springer1
- Year: 2018
Re: check spark plug
Just make sure that when beginning to insert the new plug to use your fingers to get the thread started - don't use any sort of wrench until it's threaded in and seated. This avoids cross-threading.
Also turn the slowly plug backwards until you feel it drop into the plug threads. Then tighten.
