150pcxer
Posts: 76 Joined: Tue Sep 22, 2020 5:35 am
Post
by 150pcxer » Sat Jul 17, 2021 8:37 am
Hi all,
It appeared after starting the engine for a few minutes for the first time of the day after being left overnight.
There is also a burnt smell while the engine runs.
springer1
Posts: 787 Joined: Thu Jun 22, 2017 10:28 pm
Post
by springer1 » Sat Jul 17, 2021 7:25 pm
What’s the oil level look like? Put a bit on your fingertip - if it tastes sweet it’s coolant. Have you done any work to the scoot recently ?
150pcxer
Post
by 150pcxer » Sat Jul 17, 2021 11:47 pm
springer1 wrote: ↑ Sat Jul 17, 2021 7:25 pm
Recently changed to a new stock clutch, that's all.
I went to the workshop and was told that there was a problem with the "cam cover gasket", causing the leak and bad smell. Not sure if he meant the valve cover gasket.
Will be going to another workshop for another opinion.
Posts: 7768 Joined: Tue Dec 06, 2011 7:54 pm
Post
by gn2 » Tue Jul 20, 2021 6:11 am
springer1 wrote: ↑ Sat Jul 17, 2021 7:25 pm if it tastes sweet it’s coolant
If it doesn't taste sweet, its carcinogenic.
Never stick vehicle fluids anywhere near your mouth.
Or other bodily orifices.
Conelite
Posts: 382 Joined: Sun Jan 21, 2018 11:53 am
Color: Blue
Post
by Conelite » Sat Jul 24, 2021 1:00 pm
Simply judging by all the burned oil on the header, you probably do have a leak.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
