What should I do about this rust?
Posted: Sat Feb 27, 2021 9:23 am
by Carzah
I thought I would give the bike a quick wash and noticed this rust. It's the first time I've looked under here since I got the bike last year. It's a 2019 PCX 125 with about 5,000 miles.
It's the only rust I can see other than a tiny bit on the exhaust. I'm pretty new to vehicle maintenance so I'm not sure how bad this is or how to treat it.
Any help/suggestions would be appreciated.
Re: What should I do about this rust?
Posted: Sat Feb 27, 2021 9:58 am
by Jge64
wire brush it and paint on some rustoleum rust arrestor from home depot.
Posted: Sat Feb 27, 2021 9:15 pm
by Conelite
What Jge64 said. Nothing a little wire brush and rust prevention spray paint. Rust-Oleum Rust Reformer Aerosol Spray. Then paint it black.
Posted: Sun Feb 28, 2021 2:56 am
by Old Scoot
I would go back to the place you bought your scooer
Posted: Sun Feb 28, 2021 6:03 am
You've found one of the few areas of the PCX which demands constant maintenance.
The black yoke and chrome stanchions need to be rubbed over with ACF50 at least once a week, daily in winter, to stop this corrosion forming.
If the stanchions corrode in the working area it can cause oil leaks through damage to the seals and bushes.
Posted: Sun Feb 28, 2021 10:21 am
by Carzah
Thanks for the suggestions guys.
I just got done using a wire brush and some sandpaper, then applied a coat of this stuff.
https://www.hammerite.co.uk/product/dir ... th-finish/
I have also ordered some acf-50 to cover the while bike in. Hopefully this will keep it at bay.
Thanks again.
Posted: Mon Mar 01, 2021 8:30 am
by springer1
gn2 wrote: ↑Sun Feb 28, 2021 6:03 am
Thanks for that tip, I've not heard of this ...... sounds like it's a WD-40 on steroids and it's also a lubricant where WD-40 is not.
Thanks
