Forza Mf10 - Rattling noice
bonjo
Post by bonjo »
Hi all,
Not sure whats the cause for this noice, happens when accelerating only, also the motor seems to have less power at pickup.
Noice (Video) - https://vimeo.com/467431344
Has anyone had the same issue? any solutions?
Appreciate your help on this matter thanks.
bonjo
Re: Forza Mf10 - Rattling noice
Post by bonjo »
Deleted - Duplicate Post (sometimes this happens) ;)
davenowherejones
Post by davenowherejones »
That looks different than my 2014 Forza 300.
What size & year is yours?
bonjo
Post by bonjo »
davenowherejones wrote:That looks different than my 2014 Forza 300.
Forza 250 - Mf10
davenowherejones
How old is it and where do you live?
Sounds like a leaky exhaust header gasket.
Or belt slap.
How many miles on the belt?
Any aftermarket parts fitted?
How does it sound with the cover on?
bonjo
Post by bonjo »
davenowherejones wrote:How old is it and where do you live?
2008 Mf10
bonjo
Post by bonjo »
gn2 wrote:Sounds like a leaky exhaust header gasket.
Or belt slap.
The bike had been left aside for 8months.
Didint look like belt slaps as the sound happens only in high RPMS
Not sure about 2000-5000Km
Exhaust is after market.
Same and can be heard by 100feet apart while passing by.
Few other tips i got was.
Clogged fuel pump.
Clutch spring issue.
Check the exhaust connections.
bonjo
Post by bonjo »
gn2 wrote:Check the exhaust connections.
Seems to be like the inner part of the exhaust is broken even the DB killer was laying inside the exhaust so their has be some chipped parts inside. Thanks for the info btw
bonjo
Post by bonjo »
Just fitted the stock exhaust and still got the same noice.
easyrider
Color: blk
Post by easyrider »
Seems like there excessive belt play on acceleration, but not the cause of the rattle noise. Check rollers use steth to see if noise coming from clutch housing or variator.. A new belt wouldn't hurt as a starter.
springer1
Post by springer1 »
bonjo wrote:Just fitted the stock exhaust and still got the same noice.
Header gasket fitted OK ? It sure sounds like a header/pipe leak.
