Headlamp type
OriginalRocket
Headlamp type
Post by OriginalRocket »
Headlamps, what is the bulb designation. All I can find is that it is a 25/25 watt bulb. I'm wanting to see what upgrades I can do but need to now what type of bulb it is.
khaosaming
Re: Headlamp type
Post by khaosaming »
12v 35/30w HS5
honda number 34901-GFM-971
http://www.hondapcx.org/viewtopic.php?f=2&t=676#p9909
http://www.partzilla.com/parts/detail/h ... M-971.html
...unless you are in Thailand, where the bulb is non-halogen.
cessna151
Re: Headlamp type
Post by cessna151 »
I've been wondering too. I'm getting the impression it is not a standardized bulb/connector.
khaosaming
Re: Headlamp type
It's 12v 35/30w HS5 Stanley (Honda number 34901-GFM-971).
Image:
http://makinaparts.com/lang-en/honda-en ... -lead.html
Wiring diagram:
http://www.hondapcx.org/viewtopic.php?f=3&t=556&p=8138
cessna151
Re: Headlamp type
Post by cessna151 »
That is quite disappointing. Anyone know of an easy retrofit, or adapter to use standardized bulbs?
Re: Headlamp type
I don't think an adapter would fit. If you took the assembly out, you might be able to retrofit other bulbs on, but that would likely prove difficult. :(
Re: Headlamp type
cessna151 wrote:That is quite disappointing. Anyone know of an easy retrofit, or adapter to use standardized bulbs?
It is a standard bulb, widely available.
OriginalRocket
Re: Headlamp type
Not in the USA. I can't find anything! Except OEM replacement. And only through the dealer special order.
