installing pcx braided brake lines.
Posted: Thu Jul 09, 2020 9:52 pm
				Has anyone have problems installing braided brake lines.  Did you guys use existing OEM existing brackets,
https://hondapcx.org/
I always try to use them as far as possible. Just takes a bit of ingenuity. Main issue is that they are thinner...pcx888 wrote:Has anyone have problems installing braided brake lines. Did you guys use existing OEM existing brackets,
do you have any pictures of your installation.you you wrote:I always try to use them as far as possible. Just takes a bit of ingenuity. Main issue is that they are thinner...pcx888 wrote:Has anyone have problems installing braided brake lines. Did you guys use existing OEM existing brackets,
pcx888 wrote:do you have any pictures of your installation.you you wrote:I always try to use them as far as possible. Just takes a bit of ingenuity. Main issue is that they are thinner...pcx888 wrote:Has anyone have problems installing braided brake lines. Did you guys use existing OEM existing brackets,
