				Dark coloured dipstick
				Posted: Mon May 18, 2020 4:43 pm
				by Yorkie150
				Does anyone know if there is a replacement  dipstick for the PCX that is manufactured in a lighter colour so that the level is easier to read ?
I cannot fathom why Honda manufactured a black dipstick for measuring  a dark coloured fluid ?
All my Honda engine  lawn mowers have white oil dipsticks - but sadly they dont fit
				Re: Dark coloured dipstick
				Posted: Mon May 18, 2020 7:37 pm
				by HondaC110
				Beats me.
My Subaru has the same thing going...the dipstick is phosphated,  so it's black. I buffed it off around the applicable area.
You have to wonder what they were thinking.
				Posted: Tue May 19, 2020 9:26 am
				You could buy an aftermarket one from someplace like Powerbypcx.com
https://www.powerbypcx.com/en/accessori ... kers-black
				Posted: Tue May 19, 2020 9:33 am
				by Jge64
				It’s hard to check the dipstick if you’re not in good light. So I changed my procedure, instead of changing the dipstick. Whenever I go for a ride that involves a short stop to run an errand ,like picking up a prescription ,I put it on the center stand before I go in the store. When I come out of the store, in bright ,direct overHead sunlight, I check it. I always get a good reading because you can see where it’s wet or dry.
				Posted: Tue May 19, 2020 10:15 am
				by Conelite
				Curious how often you check your oil for this to be an issue?
				Posted: Tue May 19, 2020 11:07 am
				by easyrider
				Paint it white??
				Posted: Tue May 19, 2020 11:12 am
				by Jge64
				Conelite wrote:Curious how often you check your oil for this to be an issue?
This really is a good point,  I didn’t check my PCX more than two or three times a year. If my storage spot was clean,( no leaks), and I absolutely knew how much I was putting in, I didn’t check it. I knew it was in there. My PCX never burned oil.
I do have to say,  Yamaha made a real advancement when they went to the oil sight glass. All you do is look- no messing with the dipstick.
				Posted: Tue May 19, 2020 3:28 pm
				easyrider wrote:Paint it white??
I wouldn’t just in case it flakes off. Unlikely but......
