Forza 300: Key Replacement - HOW ???
M0T0Geezer
Year: 2015 FORZA 300
Color: RED
Post by M0T0Geezer »
I just bought a used 2015 Honda Forza. The previous Abuser lost the extra ignition key along with the ID key "tag."
I believe the ignition key has a chip which would make duplicating difficult.
Has anyone else found out the best way to acquire a working second key?
2015 Forza 300
All My Motorcycles:
https://www.dansher.com/mywheels.htm
Musicians: Some Songs For You:
https://www.dansher.com/audio/pdf_tunes.html
My Domain, Home Page:
Old Scoot
Re: Forza 300: Key Replacement - HOW ???
Post by Old Scoot »
Try a Honda dealer
davenowherejones
Post by davenowherejones »
The key does not have a chip. The ignition cover does have a magnet sequence.
I have made it so that my ignition cover cannot be closed with a bit of silicone.
A good locksmith can cut you a generic key but they have to pay attention to the shoulders. Try the key before you leave. I had a few cut wrong until they figured it out.
I had a few extras cut. One in my house, one hidden on the bike, one in my jacket.
The magnet key was available from China once upon a time. It came with small magnets that you put on the old key to get the north/south alignments right for your scooter. You inserted them into the key and covered them up with a bit of tape.
Good luck getting this done at a dealer. Most of the dealers don't even know what a Forza is.
davenowherejones
And just a comment about keys in general. Your bike key ring should be minimal.
Mine has the Honda key, the GIVI key and a LITTLE RED tag so I can find them easily.
Having 30 keys on the ring is stupid. The same goes for your truck. Some of the new cars don't even need a physical key anymore.
I was riding my Forza too much. I came home and went to bed. The next days I could not find the keys. I looked almost everywhere. My Olympia riding suit has at least 22 pockets. I had put the keys into a pocket I don't normally use.
easyrider
Color: blk
Post by easyrider »
There is no chip.. Just cut the blank as you would do to any key.. The shutter door is not really necessary to lock as stated by Dave (above).Good idea to glue it shut also stated above by Dave..
M0T0Geezer
Color: RED
Thank you for the quick help, everybody. After I started this thread a few days ago I found an earlier one on the subject of ignition key replacement with lots of good advice too. Here is the link to it as additional reference for those who come here:
https://www.hondapcx.org/viewtopic.php?t=228
'Geezer
2015 Forza 300
All My Motorcycles:
davenowherejones
easyrider wrote:There is no chip.. Just cut the blank as you would do to any key.. The shutter door is not really necessary to lock as stated by Dave (above).Good idea to glue it shut also stated above by Dave..
I glued mine OPEN. :lol:
Warlock1954
Post by Warlock1954 »
When I bought my 2014 Forza it only had 1 key. Blanks no longer available at Honda shop but plenty on ebay. Now if you order a blank order you 2 of them. First one tried to cut the key and ruined it. Now called everywhere for someone to cut the key and no one would touch it. Finally a Honda dealer 100 miles away has the Honda machine to cut it. Once I got up there they couldn't cut it due to the piece on the key that opens the trap door on the ignition. So I took some cutting pliers and cut it off and they was able to make a key for it. Now I took the ruined key and put it with the key they cut and the ruined key will open the trap door. So 200 mile round trip, $35 for blank keys and $10.75 to cut it I now have a spare working key. He tried to match up a Honda key for it and couldn't match one. Now a happy camper
cyranoonline
Post by cyranoonline »
The Honda Forza key is standard except for the depth, so a locksmith will have to cut the key using the appropriate blank and then file down the base of the key so that it is long enough to fully engage. I had it done by Weston at Dup-A-Key in San Diego 858-750-2224, great work, reasonable cost. You can call around to your local locksmith to see if they can do it, look for an old school locksmith, or have it cut and grind it yourself. Of course that is just for an extra key, without the magnet locking part. I believe you can order the ones with the magnetic locking system on Ali Express:
https://www.aliexpress.us/item/32568033 ... pt=glo2usa
SpaceCoastForza
Post by SpaceCoastForza »
Another 2024 Update, I'm posting because this thread was the best resource I found in my search. I hope to add to the knowledge base just a bit.
I got a 2014 Forza 300 in November 2024, with about 14,000 miles on it.
I assumed it was a chip key -- wrong. I found and ordered the blanks on eBay. Oops, I actually ordered them on Amazon.
$25 for a pair.
https://www.amazon.com/dp/B0BNMCS7TC
On eBay, a listing that should work would be this one or similar, using a search like "forza 300 key blank 2014 honda"
https://www.ebay.com/itm/155049898903 Two keys for $25ish plus $7 or so shipping.
I took my first blank to the local mom & pop hardware store, and had them cut a key from the one key that came with the bike. The resulting key "sort of" worked. I had to jiggle it a few times to get it to turn. I decided to take the 2nd blank to a locksmith to see if I could get a better outcome, a key that doesn't stick and that I could have confidence in making copies of. I looked at locksmiths in the area and chose Y-S Locks & Keys in Orlando. He was new to Honda scooter keys, but WOW, what a fantastic job he did. He verified my blank was the correct one, using some online resources, but instead of just cutting a key from the original, he *digitized* the key pattern, mapped it into his key cutting machine, and had his CNC-like machine cut the key from the digital version. Some of the small peaks on the original key were not present in the resulting key, and I asked him about them. He explained that the original process at the dealer involved "punch machine" duplication, that didn't "cut" the key, but instead "punched out" sections of the key blank with a side impact, and that the small peaks were an artifact of that process, not an essential part of the key..
In any case, the key resulting from his process worked smoothly and flawlessly in my Forza 300, and the locksmith also gave me the key number and digital specs for cutting it, that he said most locksmiths would be able to cut the key from those specs, without needing the original key. However, I bet if I took the key he made to my same local hardware store, and had them cut a new key from it, using my blank, that the resulting key would also work flawlessly. I'll try that someday, next time I need a key.
I will key the first, hardware-store-cut, key that sticks a bit, as an emergency spare. The locksmith-cut key is the primary one I use now, and I'll keep the one that came with it as the first backup, oops-I-can't-find-my-main-key backup.
SpaceCoastForza
FYI, the key cut at the local hardware store (I supplied the blank) cost $5, and I paid the locksmith $100 + 10 tip. Blanks were $25 for two of them on Amazon.
