2 of my battery maintainers have died in one week
Posted: Sun Apr 12, 2020 8:26 pm
by big bear
ive had 2 of my litium battery maintainers that were hooked up to my pcx and x max they have both died one was only 6 months old the other one was maybee a year and a half old both deltran battery maintainers weird there not cheap 60 bucks a piece
Re: 2 of my battery maintainers have died in one week
Posted: Sun Apr 12, 2020 9:56 pm
by Old Grinner
I just got the kind of "Battery Tender" you plug into an outlet.
It's "color coded" so you can tell what stage the battery is at while it's charging.
It gets to 80% pretty quick but takes a while to get to 100%.
Maybe check into getting a regular "Battery Tender" you plug in?
https://www.bikebandit.com/manuals-tool ... us/p/34929
I've had good luck with mine . . ..
Posted: Sun Apr 12, 2020 11:42 pm
by Jge64
my lithium battery charger has a big sticker on it that says do not use it for anything except lithium batteries.It Is not a conventional charging profile. Maybe that’s the problem.
Posted: Mon Apr 13, 2020 5:34 am
by Yorkie150
I didn't realise that the battery on a pcx was lithium ...is that standard or an upgrade ?
Posted: Mon Apr 13, 2020 5:54 am
by Old Grinner
Posted: Mon Apr 13, 2020 6:23 am
by Old Grinner
On page 8-29 of my XMax Owner's Manual it says that the XMax comes equiped with a Valve Regulated Lead Acid Battery (VLRA). It gives other charging information too and a "Notice".
My 2017 PCX manual said it took a GTZ8V battery which is a Honda Part number. Here's a web site that gives the specifics.
https://www.carpimoto.it/en-US/48784_GT ... -GTZ8V.htm
I'm not sure if the PCX batteries vary for different model years or not.
The Honda Owner's manual gives the battery info on the specifications chart.
Posted: Mon Apr 13, 2020 9:06 am
by Jge64
All the PCX batteries, no matter what years, are standard conventional lead acid batteries. The VRLA aspect is just the way it vents . Aftermarket batteries can be lithium, But the stock battery is not. I use a shorai lithium in my Xmax, same size as PCX.
https://www.amazon.com/gp/product/B005F ... UTF8&psc=1
Posted: Mon Apr 13, 2020 10:34 am
by Yorkie150
I cant understand why a lithium battery requires a specific lithium charger yet the bike doesn't need any adaptation - its charging a lithium battery from the same circuitry as a lead acid battery ?
Posted: Mon Apr 13, 2020 12:13 pm
by big bear
i replaced both the x max and pcx battries with lithium battries there not oringinal there plug in battery maintainers i bought 2 new scumacher maintainers this morning i had one schumacher already hooked up
to my 2015 zuma with the lithium battery its over a year old and working fine. My sons deltran battery maintainer on his xt250 died last month i thought battery tender products were good maybee there cutting costs and making them cheap now
Posted: Mon Apr 13, 2020 1:52 pm
by Old Grinner
Good luck with your new maintainers.
Now that you mention it I think I remember you saying you had problems with your XMax battery in the past and hence replaced it.
Keep us posted on how the new stuff is doing!
Posted: Mon Apr 13, 2020 3:12 pm
by big bear
yes my x max battery dident make it through the 2018 -2019 winter
Posted: Mon Apr 13, 2020 5:36 pm
by Gil
Yorkie150 wrote:I cant understand why a lithium battery requires a specific lithium charger yet the bike doesn't need any adaptation - its charging a lithium battery from the same circuitry as a lead acid battery ?
Some lead acid chargers have other features that are bad for lithium batteries. Like desulphating feature of some, of the Lead acid battery chargers, is bad for Lithium batteries.
Posted: Mon Apr 13, 2020 7:17 pm
Be cheaper not bothering with the maintainers and swapping the batteries if required.
I've never used battery maintainers/trickle chargers and never will.
Scooter sits unused for months at a time in winter and come spring fires up first time.
Don't think I've ever had to replace a battery in a Japanese brand bike.
