The owners manual is not really helpful if you prefer to do your own service. After several weeks of waiting I finally got my service manual!
Here are a few bits of information that I would have liked to know:
Cylinder head and valves
Valve clearance IN:0.1mm EX:0.24mm
Lock nut torque 10nm
Drive belt
New: 23.4mm Service limit 22.4mm
Final drive oil:
"4-stroke motorcycle oil" SAE 10w-30
At draining: 0.12L
Brake disc
Front service limit: 3.5mm
Rear service limit: 4.0mm
Let me know if any of you need other specs or procedures parafrased here.
NSS125 Forza specifications and service info
Haarek
- Year: 125 Forza
- Shop manual
- Shop manual.jpg (164.02 KiB) Viewed 208684 times
2019 Honda NSS125 Forza.
Norway
Norway
Re: NSS125 Forza specifications and service info
Hi ....can you send me the pages refer to valve clearence and how to do it ???
Thank you
Thank you
Hi Haarek,
Great book to help those who like to do their own maintenance. So far I haven't found it in PDF or any other digital format and I know it's a general service manual but it should be free for everyone. I could have asked you a big favor, to show the part about the fuses and what each one does or what electrical part it makes up. I have a 2018 Honda Forza and the 20 Amper and 10 Amper fuses blew, and my problem was because I didn't know where it was from and what it did, but I found out by deactivating the alarm and it stopped burning these fuses, but I I still want to know what everyone does.
If it would be possible could you help me put with the pages that refer to the timing as I'm really desperate to get mine timed up, thanks
