2019 PCX 125 - air filter box
Posted: Tue Jul 02, 2019 12:12 pm
by Tommy
there's one screw in front that is so unreachable, other 5 to the back are not a problem.
any hints how to get there without taking whole sidepanel out(which would take some work I believe)
looking to remove 'snorkel' from inside of the air box ...
thnx
Re: 2019 PCX 125 - air filter box
Posted: Tue Jul 02, 2019 2:26 pm
Tommy wrote:looking to remove 'snorkel' from inside of the air box ...
Why?
Posted: Tue Jul 02, 2019 3:22 pm
gn2 wrote:Tommy wrote:looking to remove 'snorkel' from inside of the air box ...
Why?
+20bhp
Posted: Tue Jul 02, 2019 3:32 pm
by Tommy
Well, I've read here the sound gets better when rubber 'snorkel' is removed.
I know.it is placed there for at least 3 reasons
(From my experience with engines...)
1. Longer inlet reduces spitting back from the engine, because spitted particles get sucked back in before they escape the pipe
2. Better positioning of the air suction point in middle of the box/filter, better flow patter on filter(not sucking from one end/front, for example)
3. Less noise obviously than without 'snorkel'
But that aside,
Really, even for a simple filter replacement, how do you do it w/o taking the panels off?
Thanks
Posted: Tue Jul 02, 2019 4:10 pm
If its like the 2010 model I had, you'll need to take the panel off.
Maybe you could pop the pillion peg down and cut an access hole behind it?
Posted: Wed Jul 03, 2019 7:24 am
by accyuklad
is it safe to remove snorkel because wouldn't it get more shit stuck to the air filter
Posted: Wed Jul 03, 2019 4:09 pm
Top quality thread.
Posted: Thu Jul 04, 2019 1:55 am
by accyuklad
as anyone tried removing snorkel and putting k&n filter
Posted: Thu Jul 04, 2019 10:08 am
by accyuklad
Ordered simota filter instead
Posted: Thu Jul 04, 2019 10:41 am
accyuklad wrote:as anyone tried removing snorkel and putting k&n filter
K&N filter, Yes
![Thbt :P](./images/smilies/icon_razz.gif)
How-to board. Written and Performed by forum owner maddiedog 2011 model:
viewtopic.php?f=3&t=155
Posted: Sat Jul 06, 2019 10:59 am
by accyuklad
just fitted simoto I think it called and removed snorkel idle sounds same as stock setup and if you rev it when riding sounds well good but soon as you don't rev hard it seems normal
