The OD percentages quoted here assume fitting to a rim of the correct size, the PCX rims being narrower would pinch in the sidewalls/bead and could increase the diameter more than the mathmatical sum you figured out, at least in theory. Hmmmdasshreddar wrote:I would assume a 150-70 would not fit...wingz wrote:The speedo on my 150 over-reads by 10%.
140/70-14 OD is 3% more than stock.
150/70-14 OD is 5.6% more than stock.
Is there any chance that a 150/70-14 would fit on the PCX?
Would be nice if I could get a 130/90-14.
With the 140 you may have to modify the inner fender slightly (kramnala has done this).
Wider Tires
- k2apache6.0
Re: Wider Tires
My PCX mod build here..
Re: Wider Tires
Depending what year you have, but when I did mine I had to lift the splash guard that is between the rear wheel and the motor. I had replaced the stock air filter box with a canister type one which meant part of the support for the splash guard was not attached. I just simply put a ziptie through the bolt hole and attached it to the frame. It has held for the past 2½ years.k2apache6.0 wrote:Thanks for the video and spacer info. I'm about to do the same, but how much clearance is there to the shock springs, is there still room for YSS with wider shock springs to fit for example?FRossi wrote:Guys, any mod was needed at air filter box with 140/70/14?
- k2apache6.0
Re: Wider Tires
kramnala58 wrote:Depending what year you have, but when I did mine I had to lift the splash guard that is between the rear wheel and the motor. I had replaced the stock air filter box with a canister type one which meant part of the support for the splash guard was not attached. I just simply put a ziptie through the bolt hole and attached it to the frame. It has held for the past 2½ years.k2apache6.0 wrote:Thanks for the video and spacer info. I'm about to do the same, but how much clearance is there to the shock springs, is there still room for YSS with wider shock springs to fit for example?FRossi wrote:Guys, any mod was needed at air filter box with 140/70/14?
..More concerned with the tire to shock clearance measurement really, mine's a 2013. The other suff is addressed in the video mostly.
