I thought it was going to be a simple install, but they had to tear it apart Q_Q
Not very well at the moment.dkazzed wrote:Wow Valiant, would like to see how this goes.
I'm sorta thinking of sourcing a 150cc engine from the Asian market Honda CBR 150Rs. Not that i need the extra HP, but it would be nice.
Valiant wrote:Alrighty, so I took her for a little spin about 25 miles away from Honolulu to Kaneohe along the H3(60 mph speed limit, fastest zone on the island). On flat roads I'd say she can go about 70-75 mph if there's enough room up ahead to accelerate. On the windy uphill valley I was pulling about 60 mph, though I'd say I could go a bit faster maybe to 63mph if there wasn't a car in front of me. Because I was already at full throttle, I wasn't able to pass on the left(because it would take a full minute to do so, and I doubt anyone has the patience for that). That being said, 60+ mph on an uphill is hauling ass when my stock speed up that same path was 47 mph.
Downhill got interesting, as my speedo insisted I was at 80 mph for a brief moment. GPS says I was going 74 mph, but it usually doesn't register my speed unless I hold it for 5+ seconds. My 0-60 speed actually takes about 15 seconds or so. I assume that's largely because of the longer gearing outweighing the drop in roller weights(from 13g to 10g), causing pulling rpms to drop. I feel acceleration is up from 50-70mph, which is likely where the PCX is at peak rpms(8000-8500).
When I was done for the day(also went around Diamond Head, so about 40 miles total), I took a picture of my gas usage:
Was topped off before I went, fuel economy was 86.7 mpg when I spent much of my time at 60 mph or higher. Previously my fuel economy was about 82-83 mpg. So I'd say overall I gained top speed, hill climbing power, and fuel economy.
Not too bad given my lack of a throttle body and manifold(the 31mm intended to be used with the kit). It'll be interesting to see what would happen with that number with the complete setup. Right now it should be running a little rich all around, but lighter weights and the Malossi delta clutch might cut into the fuel economy, especially at lower speeds. Ultimately I think the gearing would keep it neutral relative to where I had it(82-83mpg) prior to the install.
I only tested that for about 5 seconds, during which it went up to 80 mph. The reason I stopped was because it vibrated enough to move the PCX sideways even on the stand, and because there was a sudden heavy stench of gasoline. It might also be worth mentioning that I was running it on the stand right before the engine started to die out.dasshreddar wrote:Valiant, I know the "H3" you are talking about, 60mph up that on a PCX is impressive...
How fast can you go on the center stand now?
You might be able to get above the 74gps but you probably would have to hold that 80speedo speed for like several seconds...
Some of my gps speed testing has taken upwards of 30 seconds for all the satellites to link up.
