I ordered the following from ebay Germany.
Why would using all sliders drop the longest gearing on the Forza at rpms above lockout when sliders always give more top speed on every other scooter they are used with including the PCX? Does the Forza use some kind of odd size that the sliders don't come in?BRed wrote:Yes, you will regain most of the topend back......
going to all sliders dropped your gearing right across the entire range of the variator.
The three rollers will be taller than the three sliders and will restore the original gearing so you won't redline before you reach 85.
I know your mind is set but there is another critical dimension you have always overlooked when talking about the sliders. The control edge that stops the travel up the ramps is much thinner with the sliders since they are not round. So even though they offer a lower starting gear ratio for quicker take offs, they travel farther up the ramps than a round roller with a thicker dimension can. So, as hundreds of user's on all different forums have posted over the years, DrPulley sliders always provide a longer final gear than stock, and a higher top speed.BRed wrote:If you've read the thread, then you know 23x18 Honda rollers are 23.27mm
23x18 DR Pulley sliders are 22.35mm across the same dimension.
You need a tach. Best accel with a PCX will be with weights set to pull at the power peak of 8,300 rpm. This is pretty high for fuel economy though unless your commute has you cruising at above 50 mph to get them locked out to the longest ratio. I'm running 12 gm sliders which were 8,000 rpm in the original variator, and 7,800 rpm with the new parts. I could have gone to 11 gm.vamootsman wrote:Do you have any thoughts or data on what would be an optimal combination for PCX 150? I'm running 12.5 gram rollers at the moment.
If 20 kph intervals happen too quickly you can do somthing like 40-80-60-100-80-120. So we can see cruise, acell, and coast down rpms. Also, standing start timed runs always include the big lag in applying full power that is programmed into the fuel computer so a rolling start from 15 or 20 kph can help eliminate this variable from the times. Another good metric I use is to find a steep hill (not many in Netherlands?) for the tests to more clearly show at which rpm the bike is making the best power.Mario wrote:Sendler,
I will try to make the video of the 40/60/80/100 km/h gun up's, but I think the numbers will change a lot when the Forza is completely run-in and provided with high-grade synthetic oil.
sendler2112 wrote:If 20 kph intervals happen too quickly you can do somthing like 40-80-60-100-80-120. So we can see cruise, acell, and coast down rpms. Also, standing start timed runs always include the big lag in applying full power that is programmed into the fuel computer so a rolling start from 15 or 20 kph can help eliminate this variable from the times. Another good metric I use is to find a steep hill (not many in Netherlands?) for the tests to more clearly show at which rpm the bike is making the best power.Mario wrote:Sendler,
It is a nice quality replacement and comes with different springs to set a higher launch rpm to give you more jump in the first few feet upon take off.Mario wrote: hit clutch with the numbers? and is it recommendable?
Watching the video again I see the rpm change inherent with the sliders that the op is trying to level out by mixing rollers. The take off snaps nicely to 5,500 rpm and then quickly to 6,000 when the ecu lets the power hit, due to the lower starting gear of the sliders and then moves to linger at 6,400 breifly during the transmission process and then drifts up to 6,800 as he has described instead of holding level at 6,400. After which the rpms begin to rise linearly with speed due to the variator being locked out as all CVT's will.Mario wrote:http://www.videodoubler.com/combo/saved/1251
