Page 4 of 5
Re: How-To: Change Final Drive Oil
Posted: Sun Jul 09, 2017 11:34 pm
by jhongskiecruz
Guys, My PCX had 3,250km now since i bought it,do i need to change the final drive oil?
Posted: Sun Jul 09, 2017 11:36 pm
by jhongskiecruz
maddiedog wrote:Per the maintenance schedule (http://hondapcx.org/viewtopic.php?f=15&t=323), the final drive oil should be replaced every 2 years. I recommend you change it more often if you ride a lot -- around 10k miles, my oil still looked good, but had some glitter in it. I would say 10k miles or every 2 years at minimum. You could do it every oil change if you want -- it's a 5 minute job once you've done it once.
Here's Honda's word on the maintenance:
If you're concerned your levels are low, put the bike on the centerstand and take off the top bolt. Add oil using a syringe until it comes out of the hole. Simple!
I use 10w30, as recommended. ANY (n) w30 oil will work, but you can find 10w30 the easiest. I recommend you use synthetic oil.
Here's the tools we'll use -- a syringe, a container for the oil, and 12mm ratchet with extension. The syringe is necessary -- due to the angle and size of the hole, a funnel will not work. The syringe I'm using is a standard medical syringe. Even a turkey baster will work.
Here's where the 3 bolts are on the PCX. Wipe this area clean before proceeding with maintenance. It gets REALLY dirty because the vent for the variator and clutch is just in front of the bolts.
The top left bolt is the fill port. The top right bolt you won't touch, it's one of the 7 bolts that holds the other side of the drive casing in place. The bottom bolt is the drain bolt.
Put your PCX on the sidestand. Place the cup under the drain bolt. Remove the drain bolt.
About 7oz of oil will come out. The stock oil will smell funny, gear oil has a particular smell to it.
Put the drain bolt back in, and remove the fill bolt.
Dispose of the oil responsibly. Clean your cup out. Open your new oil and pour about 8 ounces into the cup.
Put your bike on the centerstand. Get out your syringe, and start syringing oil into the bike. Your oil should be amber in color. I did this how-to by request, so the oil in my bike is new enough that I just put it back in (that's why the oil you see is darker).
Keep pumping oil into the fill port until oil flows out when you put it in. At that point, just put the fill bolt back in, and you're done!
If you have any issues / questions / etc, feel free to reply or PM me.
If this how-to saved you a few bucks or made your life easier, you can buy me a beer using the yellow "Donate" button all the way at the bottom of the page. I host the site out of my own pocket, and provide it all ad-free for the public. I even make all these awesome how-tos for free, so even a tiny donation means a lot to me personally. ;)
Why are you putting back the old oil?
Posted: Mon Jul 10, 2017 12:01 am
by alx123
I found this at Honda Thailand for $1.50..
I'm still thinking this or just use the Honda 10w30
Why do we alwaya have to overthink things? LOL
Posted: Mon Jul 10, 2017 12:40 am
by homie
You people are missing something, wondering off the reservation in these oil threads again. Honda places value on the additive (Moly) for the little bikes oils. It's recommended in the service manual for both engine and final reduction gear box. It maintains the aluminum reservoirs as well as having proper lubrication properties concerning friction. We can do pictures if you like.
https://www.amazon.com/gp/product/B0039 ... UTF8&psc=1
Now stand by for a wide variety of opinion why this should be ignored :lol:
Posted: Mon Jul 10, 2017 1:29 am
by alx123
It's normal for Honda to want us to consume their own products..
Now stand by for a wide variety of opinion why we should just stick to what the manual says :lol:
Offtopic: Went to Honda today to buy the gear oil and I'm glad to see that they also have a Fully synthetic 10w 30. probably gonna go with this one next oil change..molly or not
http://www.bigbike-thailand.com/reviews ... thetic_4t/
Posted: Mon Jul 10, 2017 7:10 am
by easyrider
I think you are right.. Avoid over thinking this. Any good quality oil , changed regularly, and the bike will out live your strictest expectations. Ride on, and forget about the advertising hyperbole. Honda does not refine oil ..they buy it !
Posted: Mon Jul 10, 2017 11:01 pm
by alx123
Update; changed final drive oil yesterday, one year since I bought the PCX. Oil look a little dark but not dirty. No metal particles..
Posted: Tue Jul 11, 2017 12:44 am
alx123 wrote:Update; changed final drive oil yesterday, one year since I bought the PCX. Oil look a little dark but not dirty. No metal particles..
Was that just from looking at the flow of oil or did you let it settle and check what was at the bottom of the container?
Posted: Tue Jul 11, 2017 2:32 am
by alx123
Drained oil was put inside a transparent plastic bottle. Will see again later if some particles settled down at the bottom overnight..
Posted: Tue Jul 11, 2017 4:44 am
by jhongskiecruz
how many km's done,before you change final drive oil?
Posted: Tue Jul 11, 2017 5:54 am
That's more or less how in noticed mine. Nothing appeared as it was flowing out but when I decanted the used oil I was surprised at the residue.
Yours hopefully will be different but it's good to check :D
Posted: Tue Jul 11, 2017 8:22 am
by alx123
@youyou
I checked again, no residue
Posted: Tue Jul 11, 2017 10:40 am
alx123 wrote:@youyou
Perfect.
Posted: Tue Oct 24, 2017 10:57 am
by Jacito
I've never changed the final gear oil, and I have about 4300 miles on her. I know what I will be doing this weekend.
Posted: Tue Oct 24, 2017 11:23 am
by homie
Jacito wrote:I've never changed the final gear oil, and I have about 4300 miles on her. I know what I will be doing this weekend.
Piece of cake, let us know how it goes for you. I hope you will use the SM's recommended product and not dump any gear oil you have laying around in the precious :roll: Good luck!
Posted: Tue Oct 24, 2017 11:38 am
by Jacito
homie wrote:Piece of cake, let us know how it goes for you. I hope you will use the SM's recommended product and not dump any gear oil you have laying around in the precious :roll: Good luck!
I always follow what is the recommended. I have to, as I'm not a mechanic by any means.
Posted: Tue Oct 24, 2017 12:00 pm
by homie
yes we love our scooters 8)
Posted: Mon Oct 30, 2017 10:43 am
by WI_Hedgehog
homie wrote:You people are missing something, wondering off the reservation in these oil threads again. Honda places value on the additive (Moly) for the little bikes oils. It's recommended in the service manual for both engine and final reduction gear box. It maintains the aluminum reservoirs as well as having proper lubrication properties concerning friction. We can do pictures if you like.
Honda creates a scooter, that if properly maintained runs over 130,000 miles (from the longevity threads), obviously doing everything in their power to maximize lifespan, and people are questioning Honda's recommendations on how to get the most life out of them??? Seriously?
I'm with @homie, use the right fluid for the job--Honda knows their machines.
Pro Honda Product Brochure (from Honda)
https://powersports.honda.com/documents ... micals.pdf
(Notice HP4S can replace HP4 and GN4, but not HP4M. @homie called it. And thanks @maddiedog for starting this all in the first place!)
Posted: Mon Oct 30, 2017 11:00 am
by Jge64
I don’t doubt that the Moly in the Honda oil is good for the bike. I’m sure it is. However my bike won’t get more than 12 to 15,000 miles before I sell it in 5-7 years. So therefore I’ll use mobil 1 full syn 10w 30 from Walmart. same for the crankcase. It’ll be fine for me.
Posted: Mon Oct 30, 2017 7:43 pm
I just changed the oil on both of our bikes. Mobil 1 10w30 full synthetic. No problems so far, but it has only been 5 years on the same manufacturer so far. I'm pretty sure there is enough left for the gear oil change.
