Wider Tires
wingz
Color: Dark Silver
Re: Wider Tires
Post by wingz »
I'm quite impressed with the stock Dunlops on mine.
I would certainly replace the rear tyre with a larger one when the time comes - primarily to improve the gearing above 90km/h.
Redwind, did you get the standard size tyres for your PCX?
dasshreddar
Year: forzaruckuspcx
Re: Wider Tires
Post by dasshreddar »
wingz wrote:The speedo on my 150 over-reads by 10%.
140/70-14 OD is 3% more than stock.
150/70-14 OD is 5.6% more than stock.
Is there any chance that a 150/70-14 would fit on the PCX?
Would be nice if I could get a 130/90-14.
I would assume a 150-70 would not fit...
With the 140 you may have to modify the inner fender slightly (kramnala has done this).
wingz
Color: Dark Silver
Re: Wider Tires
Post by wingz »
dasshreddar wrote: I would assume a 150-70 would not fit...
I had a look and the stock tyre appears to be <20mm from some of the plastic.
Some modification would be necessary.
ScooterMan
Re: Wider Tires
Post by ScooterMan »
I'm going to speak authoritatively on this as a motorcycle mechanic and having owned over 25 motorcycles...DON'T put a 140mm tire on the rear of your PCX or a significantly wider front tire. The rim width is too narrow and will adversly affect (dangerously) the profile of the tire. It's not safe.
If they made a 110/90/14 that would be ok, or a 100/100/14...but my searches have shown they don't. I put a taller (not much wider) tire on my Elite 110 to gain 4mph top speed, but the profile is still safe as it's not that much wider than the OEM tire.
2015 PCX 150 (White)[/color]
wingz
Color: Dark Silver
Re: Wider Tires
Post by wingz »
ScooterMan wrote:I'm going to speak authoritatively on this as a motorcycle mechanic and having owned over 25 motorcycles...DON'T put a 140mm tire on the rear of your PCX or a significantly wider front tire. The rim width is too narrow and will adversly affect (dangerously) the profile of the tire. It's not safe.
I would be worried about that too.
Bridgestone give recommended rim size:
TIRE SIZE..................REC. RIM (inch)..............MEAS. RIM (inch)
150/70-14M/C..................4.00...........................3.50 - 4.50
redwind
Communocrat
Communocrat
Re: Wider Tires
Post by redwind »
wingz wrote:I'm quite impressed with the stock Dunlops on mine.
Yes Wingz. Got the right size to fit the wheel size. Too bad mine didn't come with your stock Dunlop tires.
A 'real' bike is one with which you have to jump through hoops to get it to do what a scoot does with a twist
wingz
Color: Dark Silver
Re: Wider Tires
Post by wingz »
I have looked at my wheels. The front rim is 2" and the rear rim is 2.5".
So like ScooterMan said, 110/90-14 would be fine.
120/80-14 looks ok but I have only seen front versions in that size.
120/80-14M/C............2.75.............................2.50 - 3.00
dasshreddar
Re: Wider Tires
:roll:
Welcome to the Danger Zone! :lol:
wingz
Color: Dark Silver
Re: Wider Tires
Post by wingz »
dasshreddar wrote: :roll:
I would think the lean makes it less serious than having an over-sized tyre on a car.
Is it possible to move the outer surface of the tyre side to side while the wheel is stationary?
Ben2talk
Color: Grey/black
Re: Wider Tires
Post by Ben2talk »
gn2 wrote:
dasshreddar wrote:I've been thinking about installing wider than stock tires on a pcx.
Why?
The standard size tyres are more than good enough.
More than good enough on a smooth, flat road surface. That's not good enough for cross country. Some of us have varied road surfaces, our needs are not always the same.
[URL=http://www.fuelly.com/motorcycle/honda/pcx150/2015/bennn/389324]
dkazzed
Year: N/A
Re: Wider Tires
Post by dkazzed »
OP, I think what you want more than wider tires are bigger wheel diameters.
2015 Honda CB300F ABS
Oyabun
Year: `12,`15,`19
Color: black&black
Re: Wider Tires
Post by Oyabun »
I'm running 110/80 at front and 120/80 at the rear on the stock wheels - and absolutely satisfied with the results.
dasshreddar
Re: Wider Tires
Ben2talk wrote:
Why?
8) Preach on brother ;)
dkazzed wrote:OP, I think what you want more than wider tires are bigger wheel diameters.
yeah a 14" rear for the forza wheel would be nice, not sure if the pcx would be any better with say 16s"???
Oyabun wrote:I'm running 110/80 at front and 120/80 at the rear on the stock wheels - and absolutely satisfied with the results.
8) if you get a chance try some 120/140 you just might be more satisfied...
db22
Re: Wider Tires
Post by db22 »
This is a huge topic over at the Honda SOHC4 forum, where customizers put modern very wide rubber on their '70s CB750 and 550 rat bikes. I was tempted, and the traditionalists talked me out of it. I have been told that transitioning from a motorcycle to a scooter involves a learning curve, particularly in the corners, so fitting tires that improve cornering interests me.
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride...
FRossi
Re: Wider Tires
Post by FRossi »
Guys, any mod was needed at air filter box with 140/70/14?
Anyone had problems with wrong rim size? That my only concern...
Re: Wider Tires
FRossi wrote:Guys, any mod was needed at air filter box with 140/70/14?
Yes you need three steel spacers, easy mod see my video.
As for why did I need to go wider... LOOKS. If you do your PCX will look filled out, rounded, cosmetically balance, beauty and symmetry in motion!
Ride on you pencil sticks, you spindly, skinny, slippery, teeth chattering, fuel conscious stock tire PCX owners. No thank you, never looking back.
I ride with the Michelin MAN!
FRossi
Re: Wider Tires
Post by FRossi »
Homie, thanks for the advice! My PCX is the 2013 one, I dont know if the spacers will be needed. Just in case I will carry a tube for making them.
Did you also had to change the bolts for longer ones?
Re: Wider Tires
FRossi wrote: Did you also have to change the bolts for longer ones?
Oh I see now that you show your year, good man sorry.
For late 14's and 2015's you will need two bolts for the breather box, 1/2 inch longer than what you have since those are 1/2 inch spacers. The fender bolts was already long enough to handle the spacer.
txpcx13
Year: 13&14
Color: Rojox2
Re: Wider Tires
Post by txpcx13 »
Here is a really cool and helpful calculator to help you with tire width etc... should be helpful when you find some tires and want to compare them to OEM.
https://www.tacomaworld.com/tirecalc?ti ... -110-80r14
From my research I have done it seems like the easiest is to stay 90/90 front and move from 100/90 to 110/80 in the rear using City Grip tires.
It is so hard to find 14" tires for our PCX, and after much looking this is what I will go for in the future.
This setup for the rear tire is 10% wider and you will only lose 1/2 a mph at 65mph compared to stock.
2013 Honda PCX (Red) - NCY 13g rollers, golden variator, drive face, YSS shocks, Givi E450
2014 Honda Forza (Red) - Adige 17g rollers, Kappa K466
k2apache6.0
Re: Wider Tires
Post by k2apache6.0 »
Thanks for the video and spacer info. I'm about to do the same, but how much clearance is there to the shock springs, is there still room for YSS with wider shock springs to fit for example?
My PCX mod build here..
