Yuminashi help!!!!
Re: Yuminashi help!!!!
I'd be checking all of the hoses and clamps...
I have pretty much checked everything other than replacing the thermostat. I can actually see the splits in the radiators and where it's leaking.they always seem to split in the core right on the front or back of the tubePcxdemon wrote:I'd be checking all of the hoses and clamps...
Maybe change the thermostat, it is fairly cheap.Hobbs469 wrote:I have pretty much checked everything other than replacing the thermostat. I can actually see the splits in the radiators and where it's leaking.they always seem to split in the core right on the front or back of the tubePcxdemon wrote:I'd be checking all of the hoses and clamps...
And when you torque in the radiator to the crankcase, use your hands, not your impact gun. Do not overtorque it. Might be the reason that it breaks too often. I have never seen a broken radiator before in my life, unless you are mounting it wrong or some sorts.
BPT7594 wrote:Maybe change the thermostat, it is fairly cheap.Hobbs469 wrote:I have pretty much checked everything other than replacing the thermostat. I can actually see the splits in the radiators and where it's leaking.they always seem to split in the core right on the front or back of the tubePcxdemon wrote:I'd be checking all of the hoses and clamps...
The thermostat is my next step. That's the only piece I haven't replaced that would possibly make it build pressure. And I usually use a 1/4 drive ratchet to put it together, so I don't think I am over torquing it.
