Hi mate, still alive and kickingWhiteNoise wrote:How's the Op doing, RichyP? Are you around Rich...everything okay? We have not heard from you again on this thread since the startPlease clock in, and say hi
Came off!!!
- RichyP
Re: Came off!!!
- easyrider
- Color: blk
Re: Came off!!!
Hope it all turns out well, but I know taking roundabouts in the PCX requires a slow vertical position( as much as possible). Roundabouts do tend to create havoc when coming off straight ahead speed and then abruptly hitting a relatively radical curve and when its wet its even more critical to be vertical as possible.. We all are sometimes in haste and try to get low in the turns but with this scoot wet oily roads just means a slide into home plate. Good luck with the arm and hope your policy covers you completely with a new PCX ..
