Bash On! wrote:WhiteNoise wrote:Both Great tips and advice from gn2 on use of clutch
Reasonable people can differ. I usually don't put the bike into neutral at stops unless both hands are needed for some quick task. Keeping it in first gear allows you to quickly move the bike in case a distracted driver doesn't see you stopped (eye on mirrors until vehicle behind you fully stops) or you need to get out of the way of some other mayhem. More distracted drivers = more need to do this nowadays.
Regarding getting into neutral, you'll quickly figure out how your bike likes to be shifted. As already mentioned, shifting into neutral as you're rolling works, as does experimenting shifting either up from first or down from second. You can also slightly let out the clutch, rolling forward a smidgen, and then re-engage the clutch. Sometimes that's enough to move transmission "stuff" into better alignment.
If you don't pop it into neutral how are you going to wave at people that you deep down wont impress no matter what you do.
