PLease read and view my post more carefully, it's all explained. Including the wear trace etc...sendler2112 wrote:Are you sure the pulley halves will really be touching on an otherwise stock vario after the milling? Did the belt wear track on them move up after you milled them? I ask because I had understood that the rollers in the ramps were the actual stop of pulley travel. And this is why DrPulley sliders create an increase in top speed at redline when installed. Because they are thinner in the area of the stop so they can move the pulley farther than the rollers could.
No, after you put DP, it won't stop the pulley from moving inward (by the slider). The stopper of the movement will be the halves end. The easiest way to prove it is just to install it without any modification first and see whether I'm right or wrong.
After you install DP without filing anything you will notice that the pulley touched. It's a risk free installation. If you feel that you need more top end then you can mill/file it down, otherwise just leave it intact.
