Yes, shim type valve adjustments are required. Yamaha calls them "adjusting pads". They come in a variety of sizes.Old Grinner,
Am I right in thinking that the XMax 300 uses shim-type valve adjustments?
Man, this may also be MY last & final bike choice!
Tks~
See the chart on this Yamaha Parts page and look for piece 13. You'll see they list it numerous times in different thicknesses.
https://www.yamahapartshouse.com/oempar ... 76cc/valve
The upside is that the recommended schedule to check and adjust the 4 valves is every 12,000 miles or 19,000 Km.
FWIW I have absolutely no regrets buying my XMax 300. I would do it again . . ..
If I had to complain about anything it would be that I wish the high beam LED was a bit brighter at night. Distant reflective road signs or other reflective surfaces stand out in the darkness OK. It's just that I wish it had a bit more intensity of light on the road surface itself. That said, I don't do much night riding anymore anyways.
I was impressed with how quick it is and I have no problem keeping up with traffic on highways with 65 MPH speed limits. It has power to spare . . ..
