Page 11 of 13
				Re: Takegawa Pcx 170cc
				Posted: Fri Mar 21, 2014 4:33 am
				by Pcxdemon
				I made a new mod on the Pcx yesterday. I got something out of it that i didn't expect at all! Im still trying to find a better explanation for it but i cant....
I decided to make a shroud around the back part of the radiator cover to scoop and force air thru the radiator rather then leave the most of the work for the fan to do.I know the bottom right fairing is modelled along the radiator cover grills to get air in as you move forward but i thought i could use alot more cooling for my 170cc set up. Up until yesterday,my return rad hose was always quite hot to touch and same with the radiator,that engine ran quite hot and at its cooling capacity. I thought of just upgrading the cooling fan as Yuminashi has one that has higher airflow rating and that would be suffice but i thought that,that would come at the expense of power though,as it would add extra drag on the crank...So i envisaged making a better force fed cooling while in forward motion.This thing really scoops great amount of air and rams it thru the rad fins,so much so that my rad return hose is luke warm after the ride and i can finger touch the radiator without burning my self..
BUT! I didn't expect improved performance from this mod though! But it did...Two things are possible here; 1. engine is running cooler and more efficient with very little power loss due to less heat OR I have reduced the drag on the airfan on the crank behind the rad cos there is a lot more air coming to it and making it spin alot easier.... My mid range power is literally explosive on half throttle,time between 60kmh to 90-100kmh is blistering in scooter terms,it doesnt feel like a scooter,i mean this thing has some serious poke.First thing to my mind came when i noticed it was "geepers!!" 'where that came from?!!" I really thought i had it at its max performance but this shroud made and gave something totally unexpected...LOVE IT!
				Posted: Fri Mar 21, 2014 5:00 am
				by Kman2k
				Please see the 2 links on the last page, which 160 kit should I buy ? because I don't know what was the previous model (pcx) engine number/type
				Posted: Fri Mar 21, 2014 5:20 am
				by Slickvic
				Pcxdemon wrote:I made a new mod on the Pcx yesterday. I got something out of it that i didn't expect at all! Im still trying to find a better explanation for it but i cant....
Pics!!  We need Pics of this Mod!   Oh please....
				Posted: Fri Mar 21, 2014 7:15 am
				by Mgalutia88
				VLAD PICS!!!!!!!!!! and a write up how-to!
				Posted: Fri Mar 21, 2014 10:11 am
				by dasshreddar
  they make those scoops for gy6s, maybe those can be modded to fit the pcx...
				Posted: Fri Mar 21, 2014 4:45 pm
				by Pcxdemon
				Mgalutia88 wrote:VLAD PICS!!!!!!!!!! and a write up how-to!
Today sometime when i get a moment i will...for how-to,one will have to use its own imagination and what are available materials for construction in ones possession.
				Posted: Fri Mar 21, 2014 11:52 pm
				Pcxdemon wrote:Mgalutia88 wrote:VLAD PICS!!!!!!!!!! and a write up how-to!
One might not bother.
				Posted: Sat Mar 22, 2014 1:51 am
				by Pcxdemon
				you you wrote:Pcxdemon wrote:Mgalutia88 wrote:VLAD PICS!!!!!!!!!! and a write up how-to!
Each to its own,no need to write anything if its not your cuppa...
				Posted: Sat Mar 22, 2014 2:50 am
				by Pcxdemon
				Posted: Sat Mar 22, 2014 12:52 pm
				by Mgalutia88
				What did you use to start from?
				Posted: Sat Mar 22, 2014 3:00 pm
[/quote]
One wouln't
Needling aside, interesting to see the 1.5kg weight reduction in the battery. Arguably the most tangeable tuning mod. Did you notice any difference in the performance of the batteries?
				Posted: Sat Mar 22, 2014 7:08 pm
				by Pcxdemon
One wouln't
Needling aside, interesting to see the 1.5kg weight reduction in the battery. Arguably the most tangeable tuning mod. Did you notice any difference in the performance of the batteries?[/quote]
No,starts exactly the same,but should last little longer than the old one,its stronger slightly...
				Posted: Sat Mar 22, 2014 7:10 pm
				by Pcxdemon
				Mgalutia88 wrote:What did you use to start from?
Well....,i used the open face helmet visor. It was making my helmet too noisy so i was gonna get rid of it but an idea shot thru....
				Posted: Mon Mar 24, 2014 10:02 am
				by Slickvic
				Pcxdemon wrote:Mgalutia88 wrote:What did you use to start from?
Hey thanx for the pics!  That looks like a fairly easy DIY project.  I have a CPU fan shroud from a retired Dell server that I might fabricate to do what you did.
				Posted: Mon Mar 24, 2014 2:10 pm
				by Mgalutia88
				This will be interesting XD
				Posted: Sat Apr 05, 2014 2:35 am
				by Pcxdemon
				Woohoooo!!
Soon to be a 164cc yuminashi Pcx,cam and all...
Something else to play with!
				Posted: Sat Apr 05, 2014 11:10 am
				by wingz
				How about a similar scoop arrangement to get more air into the engine?
				Posted: Sat Apr 05, 2014 5:53 pm
				by Pcxdemon
				I was suggested removing the fan of the crank and installing the electric fan instead,no drag on the crank anymore..Could be doable.
				Posted: Mon Apr 07, 2014 12:11 am
				by wingz
				For combustion, I mean.
				Posted: Mon Apr 07, 2014 2:01 am
				by Pcxdemon
				wingz wrote:For combustion, I mean.
Kinda already done but i havent been trying to force it too much because i didnt have an afr meter so i couldnt tell if it would be too much for it. Ive got an afr meter now so i may have a play with forced intake sometime in the future..
