Page 2 of 2
Re: Identifying what model of PCX125
Posted: Mon Jun 01, 2015 5:18 pm
If the cylinder and head are interchangeable, why do they have different part numbers?
2011 cylinder 12100-KWN-900
2013 cylinder 12100-KZR-600
2011 head 12010-KWN-900
2013 head 12010-KZR-602
Posted: Fri Jun 12, 2015 12:44 pm
by PCX 125 CANDY RED
Same with some spares
This is for Esp 125 2013
Brake Puds
Front brake pads 06455KZL931
Rear brake pads06430KWN900
Air filter
17210KZR600
Belt 23100KWN711
Roller Weigts
22123KWN710
22123-KWN-900 Roller for 150
22123-KWN-900 Set of weights for Non ESP
So 150 is good for 125 ESP ?
Or they are all SAME ! ????
Thanks !
Posted: Fri Jun 12, 2015 12:48 pm
23100-KWN-901 Belt driven for PCX 125 NC125
23100-KZY-701 Belt driven for 150 2012
23100KWN711 I can really see on my PCX 125 ESP 2013
CRAZYY Are they all same may be when they OEM ???
Posted: Sun Jun 14, 2015 2:19 am
PLEASE HELP
Posted: Sun Jun 14, 2015 3:08 am
Different part numbers = different parts
One of the main reasons part numbers exist is to identify different parts.
Posted: Sun Jun 14, 2015 3:11 pm
gn2 wrote:Different part numbers = different parts
it is quite controversial
http://www.hondapcx.org/viewtopic.php?f ... 569#p64569
Posted: Thu Jul 02, 2015 5:35 pm
Dear best-buyer,
Hi I have checked the parts catalog for pcx 125 from 2009 to 2014.
Also pcx 150 from 2012 to 2014 and they are the same part number/model number and batch number.. 19 grams per weight 20mm x 15mm . 22123-KWN-900
The pcx range share a lot of the same components,some components have been revised but will still fit early models.
I use a pcx 150 2012 model but use the 2015 weights ...22123-K36-TOO the same part number different model number and batch number because they are 15 grams each . The first number is the part number- the second reference to model-then batch.
Parts are revised all the time the first numbers are unique to a particular part.
There are a lot of models that share the same parts,its like lots of different bikes share the same tire's and there can be many different brands to fit the same bike.
I always try to cross reference as much as possible.
Than you
Mike
