If the cylinder and head are interchangeable, why do they have different part numbers?
2011 cylinder 12100-KWN-900
2013 cylinder 12100-KZR-600
2011 head 12010-KWN-900
2013 head 12010-KZR-602
Identifying what model of PCX125
Re: Identifying what model of PCX125
PCX 125 CANDY RED
- Color: RED
Same with some spares
This is for Esp 125 2013
Brake Puds
Front brake pads 06455KZL931
Rear brake pads06430KWN900
Air filter
17210KZR600
Belt 23100KWN711
Roller Weigts
22123KWN710
22123-KWN-900 Roller for 150
22123-KWN-900 Set of weights for Non ESP
So 150 is good for 125 ESP ?
Or they are all SAME ! ????
Thanks !
Brake Puds
Air filter
17210KZR600
Belt 23100KWN711
Roller Weigts
22123KWN710
Thanks !
Smile - it's easy =)
PCX 125 CANDY RED
- Color: RED
23100-KWN-901 Belt driven for PCX 125 NC125
23100-KZY-701 Belt driven for 150 2012
23100KWN711 I can really see on my PCX 125 ESP 2013
CRAZYY Are they all same may be when they OEM ???
PCX 125 CANDY RED
- Color: RED
Different part numbers = different parts
One of the main reasons part numbers exist is to identify different parts.
PCX 125 CANDY RED
- Color: RED
it is quite controversialgn2 wrote:Different part numbers = different parts
http://www.hondapcx.org/viewtopic.php?f ... 569#p64569
PCX 125 CANDY RED
- Color: RED
Dear best-buyer,
Hi I have checked the parts catalog for pcx 125 from 2009 to 2014.
Also pcx 150 from 2012 to 2014 and they are the same part number/model number and batch number.. 19 grams per weight 20mm x 15mm . 22123-KWN-900
The pcx range share a lot of the same components,some components have been revised but will still fit early models.
I use a pcx 150 2012 model but use the 2015 weights ...22123-K36-TOO the same part number different model number and batch number because they are 15 grams each . The first number is the part number- the second reference to model-then batch.
Parts are revised all the time the first numbers are unique to a particular part.
There are a lot of models that share the same parts,its like lots of different bikes share the same tire's and there can be many different brands to fit the same bike.
I always try to cross reference as much as possible.
Than you
Mike
Than you
Mike
