How-To: Install a Trunk
Re: How To: Install a Trunk
Looking good! I like that new rack, it's nice.
PCX Commuter
Post by PCX Commuter »
I bought the Honda Rear Trunk Base 08L70-KZY-910, and it is indeed very sturdy metal construction. I have not yet installed it because I haven't decided on which trunk to get.
I'm thinking, however, that the Monolock or Monokey universal bases can easily be installed by first drilling mounting holes through the metal Honda Rear Trunk Base.
It might involve holes in a location like this: (I drew in the possible hole locations as a mock-up.)
[/quote]
Great idea! That plate is pretty heavy, but once you drill through, it would never let go! Let us know if you decide to go that way.
Currently own: 2013 Honda PCX 150, 2002 Honda Metropolitan
Previously owned: 1978 Honda NC50
sasha82
Post by sasha82 »
Very nice write up. One of the best I've ever read with all the pictures I feel it would be a snap.
Can you post a photo with your macbook pro inside the trunk? I just want to see the clearance because I'm still having trouble imaging how it would fit . It's a darn big laptop..
sasha82 wrote:Very nice write up. One of the best I've ever read with all the pictures I feel it would be a snap.
If you are concerned that the 370 won't be big enough, I put a 470 on mine. It might look oversized for the bike in pics, but it real life it doesn't look too big at all. The model I have has the brake (aim) light as well which is a nice feature. You can see it in the "Gallery" section on the "Before and After" thread.
PCX Commuter
Sure! Here you go.
Laptop E370.JPG (324.53 KiB) Viewed 9686 times
pphan26
Post by pphan26 »
Hi Pcx Commuter,
Just new to these forums and found your install guide really interesting and useful. Just bought a pcx 125 and planning on a top box install using the honda rear plate alongside the givi e370 which you have successfully carried out.
Just need some guidance with step 11 where you did some nice fancy work. Can you explain that part in more detail and also wondering how the top box and rear plate is holding up since the install.
Any guidance would be awesome.
Cheers
hawkeyegirl
Post by hawkeyegirl »
This is a very thorough tutorial! I just received my Givi box and I'm waiting on my Honda OEM bracket. I saw steps 11-11b and I'm wondering if that will be pretty intuitive when I do the install, or are there any other details you could provide on how to rig the Givi mount to the Honda bracket? Thanks in advance!
6ftMach1Girl
Post by 6ftMach1Girl »
Thank you for the great pics! I am spending way too much time on this forum!
chucktuna
I'm up to 12 or 13 now...
Post by chucktuna »
Great write up.
About the only suggestion I could add is to use these type of drill bits instead of a spade bit:
chucktuna wrote:Great write up.
Xmas trees!,,
BrAtKo
Post by BrAtKo »
Hello all any idea where to buy 08L70-KZY-910 trunk in the Europe please ? Postage from US is quite expensive. This part is not officially available on local dealers it seems it is only US part. Thanks.
I've already sold my PCX and swapped to NC750S DCT
The parts on the list are probably not the style your after, but just in case
http://www.hgbyamaha.co.uk/hgbdaytonash ... CX125.html
BrAtKo
Post by BrAtKo »
Hello all I've received Honda trunk finally today from US. I'm wondering how to mount the Givi base plate because point 11b of PCX commander photos is not so clear. I'm thinking about drilling the holes anyone already did it ? If so would you mind please to share photos ? Thanks.
BrAtKo, the mounting hardware that comes with the kit typically mounts to the baseplate without drilling. Do the holes not line up?
BrAtKo
Post by BrAtKo »
Pcx commander has used some different parts not included in honda kit and even in Givi kit.
The only hardware I don't recognize is on the bottom -- those brackets aren't the same. Typically, a washer and nut is included on the bottom, and they hold the case mounting plate to the rack.
Mel46 has a stock rack with stock hardware, hopefully he or someone else that had the rack can chime in or post pictures of whether or not they had to drill.
BrAtKo
Post by BrAtKo »
maddiedog wrote:The only hardware I don't recognize is on the bottom
Exactly same on me.
BrAtKo
Re: How-To: Install a Trunk
Post by BrAtKo »
I've already modified it by drilling four holes.
BrAtKo
Post by BrAtKo »
Hello all I've picked up mine pcx 150 2014 and finished mounting the box. First I've had to extend two holes with dremel grinder and all threads has been protected with thread locker.
jcomp5150
Post by jcomp5150 »
I just wanted to say thanks for all the info and part numbers/vendors. Here are some pics of a successful install after finding all the great advice!
Thanks.
