PCX Speedo inaccuracy
- raito
- Color: matte silver
Re: PCX Speedo inaccuracy
Here it is, my top speed video. Couldn't find a way to mount camera so that both smartphone and speedometer were nicely in view.
- alx123
- Bangkok Rider
- Color: Fast White
That's a little around just 6%. Not so bad.raito wrote:Here it is, my top speed video. Couldn't find a way to mount camera so that both smartphone and speedometer were nicely in view.
104 KPH = 64.6 MPH.
I'll try to make a video too soon. Thanks
				TheMaverick
I've measured the accuracy of my 2013/2014 model many times - it over-reads by exactly and consistently 10% at all speeds.
Actual top speed is around 100 km/hr in wind-neutral conditions (110 indicated). Rev limiter starts to cut in at about 112 indicated.
Hope this helps.
Hope this helps.
- alx123
- Bangkok Rider
- Color: Fast White
Thanks for the info, our speedometers inaccuracy are both the same.TheMaverick wrote:I've measured the accuracy of my 2013/2014 model many times - it over-reads by exactly and consistently 10% at all speeds.
Hope this helps.
				Brent
I again went by a automated speed display that was on the freeway.  I was doing 60mph and the sign said I was doing 60mph.
What bothers me more is the miles per gallon readout. For the entire two years I have owned my PCX, the mpg has been 10% over what my actual mpg has been.
Buggy.
Buggy.
				RobV
- Year: 2012
So the question is: If they're spot on in US and 10% out elsewhere - is there a switch/setting somewhere to change it?
						- Yorkie150
- Year: 2018/19
- Color: RED
ALL vehicles manufactured for the uk  have speedos that ''over read''  That is they all show a higher reading than the actual speed...This is usually 4 to 6 mph over 30 mph..
				RobV
- Year: 2012
It has a rev limiter?TheMaverick wrote:I've measured the accuracy of my 2013/2014 model many times - it over-reads by exactly and consistently 10% at all speeds.
Hope this helps.
				RobV
- Year: 2012
It seems that speedo inaccuracy is country related... ie USA ones seem to be pretty accurate.  Oz ones are 10% out.   I wonder if there's a setting/adjustment...
				DiogoPT
- Year: 2018
I am from Portugal and have the new model pcx 125 and I find that the 10 % error is also true on mine.
You notice it better when doing top speed, because the kph difference is higher.
In the milleage I don't notice any difference from the real one. I measure the amount of fuel I put and i make the same kms as the milleage tells.
				springer1
- Year: 2018
Either a rev limiter or something similar that kicks in about 67 or close mph to limit top speed.RobV wrote:It has a rev limiter?TheMaverick wrote:I've measured the accuracy of my 2013/2014 model many times - it over-reads by exactly and consistently 10% at all speeds.
Hope this helps.
