Page 2 of 2
				Re: Puncture
				Posted: Fri Nov 18, 2011 6:10 am
				by PT63
				rainburg :- The original tyres only had 5000 miles on them as i only use the bike to commute to work, so it was the nail and split in the rear tyre that forced the change. I changed the front just so it matched the rear, also because i just did'nt really trust the stock tyres  in the rain.
In Briton we have roundabout's (i don't know if you have them over there) which are magnet's for oil, mud, water and any other road dirt which makes them dangerous in the wet expecially the way people drive these days. Once the new tyre's wear in i'll let you know what i think of them
				Re: Puncture
				Posted: Fri Nov 18, 2011 11:30 am
				by rainburg
				Glad to hear you got 5,000 miles on the rear tire/tyre PT63.  I had the impression that they might only be good for about 4,000 miles, and I admit I'm not looking forward to getting them off and changed.  It would be nice if they worked just like a bicycle with quick release and small nylon bicycle tire levers;)   Then I could take care of it in just a few minutes
   Was the tire split due to the nail, or was it just the tire wearing out?  I'm looking forward to a report on the Michelins because we definitely have a positive view of the brand and they'd be first on our replacement list unless they were much more expensive or poorly reviewed.
We do have a few roundabouts in my area.  They are relatively new, and I admit that I didn't like them much at first.  Once you get used to them however they seem to work pretty well and they've helped remove some traffic backups.  I think they are rare on this side of the pond however.
				Re: Puncture
				Posted: Fri Nov 18, 2011 12:15 pm
				by PT63
				The split was probably caused by pot hole's, all the roads here have more than there fare share.
				Re: Puncture
				Posted: Thu Nov 24, 2011 12:32 pm
				by edscoot
				BUGGER
Last night at work I managed to get two flats by backing over a board with nails in that had blown over. It was dark and I couldn't see it until the headlight shone on it but by then it was too late. I thought by some miracle I had got away with it, but this morning sure enough the rear had only half pressure and the front was completely flat.
I'm getting Michelin City Grips on Monday or Tuesday which is good - I'm looking forward to these especially as my employer is going to pay for them
  But the rear IRC only had about 1300 miles on it and the front 5650 ish.
				Re: Puncture
				Posted: Thu Nov 24, 2011 12:34 pm
				by maddiedog
				Awesome, how'd you convince your employer to pay? Do you ride the scoot for work? That's a sweeeet deal.
				Re: Puncture
				Posted: Thu Nov 24, 2011 12:41 pm
				by edscoot
				It was there fault for putting the stupid board where it could cause this to happen in the first place. They should have moved it somewhere out of the way. I had to drive into work this morning in the cage at vast expense (mpg and parking). I told them what had happened and they've admitted fault.
I'm just glad that PT63 put me wise to the City Grips - Next time hopefully, I'll be able to get the Pirelli Diablos for comparison - but those Michelins look god for the wet.
				Re: Puncture
				Posted: Thu Nov 24, 2011 1:02 pm
				by maddiedog
				Ah, I misunderstood you -- I thought you ran over it at speed in the road.
I think I'm going to try to get my hands on some Diablos, but they seem to be hard to come by.
				Re: Puncture
				Posted: Thu Nov 24, 2011 1:42 pm
				by edscoot
				I've just ordered some Dyna Beads (kit 9) to go with the new tyres
				Re: Puncture
				Posted: Fri May 30, 2014 5:58 pm
				by wawctw
				Interesting discussion on tires for the PCX. I use ride on in all of my tubeless motorcycle tires. It has been proven in tests to seal a huge number of drywall screws and hold all of its air. If you have a puncture on the road a properly filled tire with the correct amount of ride on will seal it in mere seconds saving your life no doubt. In addition it will keep
Your tires in balance as long as the tire lasts. It gives me that little more peace of mind while riding and I am frequently on the highway at speeds over 70 mph for hours at a time. Check it out for yourself you can buy from their website, Amazon or Cycle Gear in the USA.
				Re: Puncture
				Posted: Fri May 30, 2014 6:27 pm
				by wawctw
				Re: Puncture
				Posted: Fri May 30, 2014 8:01 pm
				by AustinPCX
				+1 I posted a link to Ride-On on this site nearly three years ago.  I would not ride without it. This is nothing like Slime. I wouldn't waste my money on Slime or Dyna Beads.
				Re: Puncture
				Posted: Fri May 30, 2014 11:44 pm
				by wei2go
				Interesting... I've been using liquid sealant on my tubeless mountain bike tires for years. Every 6-12months I have to take the tire off and clean out the sealant that hardens over time. Is that the same with ride-on?
				Re: Puncture
				Posted: Sat May 31, 2014 8:38 am
				by AustinPCX
				No.  Ride-On is a one time application for the life of the tire.
				Re: Puncture
				Posted: Sat May 31, 2014 3:16 pm
				by wei2go
				AustinPCX wrote:No.  Ride-On is a one time application for the life of the tire.
Wow. Really, are you sure??!! Sorry about the mistrust, but I've been cleaning sealant for years. Are you telling me that I could have saved myself a lot of effort?
Have you opened and checked yourself after a year of riding?
				Re: Puncture
				Posted: Sat May 31, 2014 3:41 pm
				by AustinPCX
				Just replaced the tire today after 9 months with it the tire.  Looks the same as when it went in.  Wipes  away cleanly and easily with a damp rag. Says right on the bottle "One treatment good for the life of the tire"
				Re: Puncture
				Posted: Sat May 31, 2014 4:26 pm
				by wei2go
				Re: Puncture
				Posted: Sat May 31, 2014 4:57 pm
				by wawctw
				Austin P C X yes as I said before Ride On is great. I have used it for years in several bikes and I think that my tires due to being well balanced lasted much longer.
