when should i give up on my scooter
honkerman
Re: when should i give up on my scooter
Post by honkerman »
eggman wrote:is the replacement bearing better then the originals?
No but better than a worn out one. But they need to grease the hell out of it. The original ball bearing up inside the clutch assembly is often not greased well from from factory. Greasing the snot out of it helps keep it from wearing out and making the whoosh whoosh whoosh noise.
eggman
Post by eggman »
I cant figure out which of these parts are the clutch bearing http://www.cheapcycleparts.com/oemparts ... riven-face
honkerman
Post by honkerman »
eggman wrote:I cant figure out which of these parts are the clutch bearing http://www.cheapcycleparts.com/oemparts ... riven-face
Just get #8. it comes pre-assembled with the bearing installed. All that needs to happen is for you or your mechanic to remove the old inner face from the pulley assembly and attach the new inner face, and grease the snot out of the bearing listed as 19 in the diagram. Also #18 aught to be greased up pretty good too.
eggman
Post by eggman »
cool ty I may go get it and fix my self
chicaboo
Post by chicaboo »
eggman wrote:cool ty I may go get it and fix my self
You will need some irregular tools that most people don't tend to have to get the job done.
EG: an impact gun or clutch/variator holder tool, 39mm socket, and at least two clamps to hold the clutch.
And while you're in there, you may as well check/replace the belt and rollers depending on your mileage...
Chicaboo is correct all the way around. When ours went bad, the assembly was on back order and had been for awhile. After waiting anxiously for quite awhile the mechanic took the assembly apart himself and then went on a search for the bearings, of which one of them is irregular and very hard to find. Since that time there have still been quite a few riders who have had the same bearings go bad. Order the assembly, and if you can't install it, take it to your mechanic. They have the tools.
eggman
Post by eggman »
well she is done and seems fine ty for all the input everyone
There is always that satisfaction in a job well done...and a scooter that runs fine again. :-)
eggman
Post by eggman »
hey am I reading it correct oil change is at 8000 miles?
Stick with changing your bike oil every 3000 miles. Your bike will thank you.
