Getting a bit more OOMPH from my 2013 PCX 150
Re: Getting a bit more OOMPH from my 2013 PCX 150
Big mpg is good but...
Say a US gallon of gas is $2.20 and you ride 4000 miles a year.
A 150cc scooter doing 110 mpg will cost you $91 a year in fuel.
Swap the 150cc scooter for a 300cc scooter giving 70mpg and your annual fuel cost is now $143
So the monthly additional fuel cost is just $4.33
A small price to pay for a lot more capability ;)
Joan & Jack
Post by Joan & Jack »
Your math works! I had a Burgman 400 and got the PCX for wife. I got to like the PCX more and we decided to sell the Burgman.
2013 Honda PCX with Honda Top Case and Honda Windshield. Best documented gas mileage was 110 MPG
The PCX is more than adequate and capable for it's purpose - an urban commuter made to ride at normal urban speeds for most of it's life - not riding wide open for most of it's life and still wanting more (if Honda saved money using parts that's a wise move - everyone would do the same unless it's high cost small sales your after).
People want to tinker and spend lots more on the bike, fine - but if you need to ride at speed for most of your travels, get a bigger and better bike as GN2 states. It will be more stable, have better braking, wider tyres, and probably be more comfortable.
tbln930
Year: 2013 PCX 150
Post by tbln930 »
Huh? Gas here is approaching a $1 a US gallon. They are buying gas guzzlers (giant trucks and SUVs) here like they are going out of style. Who cares about mileage?
SECoda/tbln930
tbln930 wrote:Who cares about mileage?
Just about everyone.
Joan & Jack
Back at the ranch...my goal is to find a technical solution to squeeze a bit more speed or delay the rev limiter from kicking in so soon on my PCX. Great suggestions all. The second respondent to this thread provide a path toward my goal. I will see if I can replicate his success.
To date: I have an NCY variator, roller weights and belt. Waiting on a new left side gasket. It will be next weekend before I will be able to complete the service.
I will keep you posted!
pcx man
Post by pcx man »
The NCY is the best choose to me. That is what I have. A positive side affect to this choose for my riding style is about a 10% better mpg. I do run the OEM rollers to get this mpg. I have used litter weights and it does get you off the line quicker but for me it took longer to get to top speed. It also dropped the mpg.
tbln930
Year: 2013 PCX 150
Post by tbln930 »
I have the NCY V/FP but 13 gr rollers. It does push the top speed up a lot relative to most other changes. I suspect if you use it to run faster most of the time your mileage will drop. It may also affect belt wear a bit.
SECoda/tbln930
Oyabun
Year: `12,`15,`19
Color: black&black
Post by Oyabun »
Joan & Jack wrote:Back at the ranch...my goal is to find a technical solution to squeeze a bit more speed or delay the rev limiter from kicking in so soon on my PCX. Great suggestions all. The second respondent to this thread provide a path toward my goal. I will see if I can replicate his success.
You don't need to change the gasket if you open up the variator housing if you open it up without damaging the gasket. It helps if you start the operation with a clean bike. The gasket usually keeps attached to the variator cover. Just wipe it clean with shop towel and reinstall. I've opened and reinstalled mine several rims already and it is still as as new.
tbln930
Year: 2013 PCX 150
Post by tbln930 »
The entire install took me about 30 minutes and is documented with pictures on here somewhere. No new gaskets are needed. A way to hold the plate was really the only small challenge.
SECoda/tbln930
Joan & Jack
Thank you! Good to know. I have the tool to hold the faceplate. I will look for your pictures.
tbln930
Year: 2013 PCX 150
Post by tbln930 »
Here it is - I am also SECoda. A tach like you will see there comes in real handy. You don't need to completely remove any panels as you will see. I removed one bolt.
http://hondapcx.org/viewtopic.php?f=9&t ... ariator+13
SECoda/tbln930
Joan & Jack
OOMPH achieved! This afternoon, I removed the stock variator and installed the new NCY variator. I used new, stock Honda weights in the variator.
I live .7 miles for I-4. I eased over to the Interstate to run my five miles west to the next exit. For the first three miles, there was no interference from the Rev Limiter. I was going 65 mph / 66 mph (a slight improvement). At about mile four, the PCX bumped up to 68 - 69 -70 mph. I will add that this run is essentially flat.
I exited at the St. Johns River exit and looped around and popped up eastbound on I-4. At the St Johns River bridge. There is a slight downgrade off the bridge. I bumped to 72 - 73 -74 mph and when the road flattened out again, I held 70 mph back to my exit.
I returned. I put away my tools. I kissed my wife!
tbln930
Year: 2013 PCX 150
Post by tbln930 »
If you have a tach. You shoot for full throttle acceleration to be right near 8000 rpm. I think mine is at 7950 rpm with the 13 gram weights. It sounds as if you were able to get past the rev limiter at 67 and up into the 70s so that is a good sign. A new belt helps too and a mid Givi windshield up from stock (the tall seems to have too much drag). Everything helps (lean over). When my belt was newer I could get to about 74 mph with a long enough run and no climb whatsoever. The light weights raises the rpm and improves low to mid acceleration.
SECoda/tbln930
ok, we have discussed this before, but one more time...stock belt or re enforced one? I plan on putting a NCY variation on my wife's bike soon. Her belt only has about 3K miles on it. Should I swap it out? Who makes the best one for the swap for a 2013 model 150?
tbln930
Year: 2013 PCX 150
Post by tbln930 »
At least back then I thought the consensus was to stay stock but go new. I think I paid about $20 for a new one.
SECoda/tbln930
GeeGusKahn
Post by GeeGusKahn »
Mel,
Plus 2 on stock belt.
Consensus was a stock belt with NCY V & FP .
Need to update my sig line, using NCY V & FP & stock belt since fiasco last summer.
PCX runs like a champ with that combo.
No, not 75 mph but easy cruse at 55 to 65 with wot downhill to 71 mph.
I am running tall GIVI windscreen and for rest of winter it stays on.
Sean
Joan & Jack
First day commuting since the upgrade to NCY variator and face plate with stock belt and new stock roller weights. The PCX maintained a steady 72 / 73 mph (no rev limiter) when on the Interstate. I could not be happier with the results! (Before, the NCY upgrade, the PCX was hitting the rev limiter at 65 mph.). I appreciate everyone input! Jack & Joan
