Today is saturday so i will try to disassembly all the plastics and try from the catalog part pictures to install the parking brake.
We will see if i will make it happen.
As for the master CBS cylinder is exactly the same with the US model, i have both so i can compare them, the only difference is that the US cylinder has the metal part,which is connecting the cable for rear drum with the cylinder, a little bit longer than mine, about an inch, so be able as i can unterstand to lock the drum with the parking brake.
Parking brake
asoulakis64
- Year: 150
- Color: red
- d.a.rous
- Year: 2014 JF57(125)
- Color: Carbonium Grey
Re: Parking brake
Have built today a own parking brake. Function: Pull the left brake, push the screw with the index finger into the column, release the brake.
When you start, pull the brakes, the spring automatically brings the screw into the initial position.
- PB.jpg (86.81 KiB) Viewed 932 times
YSS G-Euro XL Red shock
Dr Pulley SR2015 13g sliders
Dr.Pulley SP2015-AK sliding pieces
SH Clutch (Facilitated)
Malossi Clutch Spring (Red)
High beam Passing (Flash)
Low beam switch (on/off)
Oxford HG "Touring"
Drive Belt Cover + Swingarm (Matt Black)
Michelin City Grip
Oxford HG "Touring"
Michelin City Grip
Re: Parking brake
Seriously... you two guys have too much time on your hands
Actually as cumbersome as that looks it is an improvement on Honda's p-brake because it auto releases. Congratulation on a better mouse trap bro! But you still might get this years nut award for silly modification
Wait... the more I think about it, I might make you a whisper'er for that because it works better than mine.
- mac2.jpg (8.47 KiB) Viewed 918 times
Re: Parking brake
Chief said he re-branded this as 'To drunk to find neutral' over by the Harley forum but don't worry you still own the intellectual property rights to parking brake.
- mac&chief.jpg (8.92 KiB) Viewed 910 times
