Yes I confirm this to be a great little tachometer although the instructions didn't say anything about tape on anything. Instructions were a little vague and assumed you knew to do this I guess. Mine is on the bars cabled down through the steering column then under the lower side panel wrapped around the spark plug cord 15-20 times... no tape, works great!sendler2112 wrote:I have the Koso tach.
http://www.amazon.com/Koso-North-Americ ... =koso+tach
It is very easy to install since it is battery powered and uses an inductive pickup wire which is just wrapped around the spark plug wire and taped.
Acceleration,vibration/speed issues
Re: Acceleration,vibration/speed issues
- sendler2112
- Year: 2013 PCX150
Just anything to keep the wire from falling off later.homie wrote: the instructions didn't say anything about tape
