Page 2 of 3
Re: First oil change for 2015 PCX150
Posted: Tue Oct 21, 2014 12:54 pm
by jkautz
SECoda wrote:Rings or valves?
I was told they're process to check the compression is to use a gauge on each cylinder/valve, I can't remember the term used. Then they have a process to figure out if the seats and rings are wearing evenly. So I'm not sure how the process was to figure it out. I just know I saw them going through the process.
Posted: Tue Oct 21, 2014 12:58 pm
by homie
jkautz wrote:lol very supportive group of guys on this forum.
very supportive group of guys with a healthy skepticism about Honda's 600 mile first service. I believe you, and a proper compression check would have satisfied me about both rings and valves. If you cooked any engine combustion sealing component in your (HOT break in) it would have failed the compression check.
Posted: Tue Oct 21, 2014 1:00 pm
by jkautz
homie wrote:jkautz wrote:lol very supportive group of guys on this forum.
Very very healthy
Posted: Thu Oct 23, 2014 9:22 pm
by pcxpower
Congratulations for your healthy engine!! Now we know that we could be a little "happier" with our break-in procedure without future regrets
Posted: Fri Mar 27, 2015 4:54 pm
by jkautz
Hit 2k miles today. Going strong! Almost time for the 2500mi checkup
Posted: Fri Mar 27, 2015 5:02 pm
by tbln930
I did it a bit early as i switched to all synthetic oil.
Posted: Fri Mar 27, 2015 5:08 pm
by jkautz
I did as well. I changed the oil @ 600 with the dealer. Did the second change myself at 1200mi. Switched to Amsoil 10w30 Synthetic. I figure for warranty sake, I'll bring it in to the dealer at 2500mi to have them do the valve check.
Posted: Mon Mar 30, 2015 12:59 pm
by pcxpower
Posted: Mon Mar 30, 2015 2:14 pm
by tbln930
How dare you.
Nice not to see any particles at all. You can run the oil through a coffee filter too but it looks pretty good.
Posted: Mon Mar 30, 2015 2:21 pm
by pcxpower
Posted: Mon Mar 30, 2015 4:14 pm
homie wrote:Some one posted for a new engine in the break in crowd;
Fire the engine and let it warm up, take a 1/4 throttle pass. Shut it down and let the engine cool.
Run the engine through a 1/2 throttle pass, and let it cool.
Run the engine through a 3/4 throttle pass, and let it cool.
Run the engine trough a full throttle pass, let it cool --- now go racing.
You need enough cylinder pressure to get the rings to seat properly but you need to give the rest of the engine time to get happy too. A new engine will invariably have some tight spots, and you want to give them a chance to burnish in without over heating them. The thermal cycles also help to get all the gaskets settled in, and if you have an engine that needs re-torquing of heads or adjusting of mechanical valve lash (and PCX owners do) that needs to settle in as well.
Not me talking... Homie don't know about these things
Utter piffle
Posted: Fri Jan 29, 2016 4:34 pm
by dariel89
did the oil change today at 630 opps went over a lil found a small piece of metal on the filter .....
Posted: Fri Jan 29, 2016 7:31 pm
by dariel89
Posted: Sat Jan 30, 2016 3:57 am
dariel89 wrote:did the oil change today at 630 opps went over a lil found a small piece of metal on the filter .....
I did and some gasket remains.
The final drive oil was worse
Posted: Sat Jan 30, 2016 10:34 am
by dariel89
you you wrote:dariel89 wrote:did the oil change today at 630 opps went over a lil found a small piece of metal on the filter .....
did you change the final gear too?
Posted: Sat Jan 30, 2016 11:16 am
Hmm, how do we get to see your tapatalk photo? Reset the size of your photo within limits
Ali, (or anyone knowing) can you get his link (further up the page) to work, and then share with us how?
Posted: Sat Jan 30, 2016 3:28 pm
by DailyRider
If you take the URL from inside the [image]...[/image] and load it into your browser,
you'll get the image below, only much much bigger.
Posted: Sat Jan 30, 2016 8:04 pm
by DailyRider
Okay, I'm no kind of expert but I've heard that it's common to see metal filings on the 1st (600 mile) service. And that doesn't look too bad.
But if someone else knows more, by all means please say so.
Posted: Sat Jan 30, 2016 8:37 pm
dariel89 wrote:you you wrote:dariel89 wrote:did the oil change today at 630 opps went over a lil found a small piece of metal on the filter .....
Yes
Posted: Sun Jan 31, 2016 10:26 pm
by honkerman
DailyRider wrote:Okay, I'm no kind of expert but I've heard that it's common to see metal filings on the 1st (600 mile) service. And that doesn't look too bad.
This is indeed normal. It won't always be the case, but it will be more often than not.
