A stiffer contra spring was an overall negative in my experience and is really only useful if you vastly increase the power of the engine beyond stock to the point that the belt starts slipping. Increasing the contra spring increases the tension on the belt which stretches it a little longer and smashes it narrower. Both of which will slightly reduce top speed. Along with the extra power that is being wasted in the belt as heat from the extra force on it. You can get the desired effect of a higher pulling rpm just from changing to lighter weights.Pcxdemon wrote: 'white' spring
Max speed, vario & rollers
- sendler2112
- Year: 2013 PCX150
Re: Max speed, vario & rollers
				Mgalutia88
- Year: 2013 PCX 150
Swap back to your stock contra spring and see what happens.
				piolob
- Year: 125 cc MY2015
- Color: red
Ok, I understand nowsendler2112 wrote:Riding in a tuck gives you a more aerodynamic way through the air for the best top speed.piolob wrote:Sorry, but what's "tuck"?
 Riding tuck I can reach 110/115kpm, but I don't know the rpm, i just got tacho two days ago; I will retry looking at the tacho
White spring is stronger than yellow one.Pcxdemon wrote:Here is a video of another pcx tuned with malossi stuff but this guy is using a 'white' spring and Malossi belt unlike your set up. Im not sure if the yellow spring is maybe to strong for stock 125 engine and may also give you hard time topping out max speed..
https://www.youtube.com/watch?v=DFV1kNB4bhs
Yellow was in the kit togheter with the vario and is 10% stronger than original one.
sendler2112 wrote:A stiffer contra spring was an overall negative in my experience and is really only useful if you vastly increase the power of the engine beyond stock to the point that the belt starts slipping. Increasing the contra spring increases the tension on the belt which stretches it a little longer and smashes it narrower. Both of which will slightly reduce top speed. Along with the extra power that is being wasted in the belt as heat from the extra force on it. You can get the desired effect of a higher pulling rpm just from changing to lighter weights.Pcxdemon wrote: 'white' spring
I dont think it's too strong, even with original pcx power.Mgalutia88 wrote:Swap back to your stock contra spring and see what happens.
I switched to it just two weeks ago: I didnt lost max speed but I gained in midrange (40-80 kpm) and uphill.
Yes, i know about ligheter rollers, but now I'm using 8 gr rollers (too light), if I go lighter I think I could reach limiter just idling
				piolob
- Color: red
Good tip, but which hand? left or right?you you wrote:Even better if you lift yer bum onto the seat and put your hand on the left fork tube
- sendler2112
- Year: 2013 PCX150
A stiffer contra spring will raise the pulling rpm. So will lighter weights. They balance each other. But the weights do it without the draw back of smashing your belt. 8,000 rpm should be the fastest setting for a stock engine. Anything higher than that is entering an area of lesser power again and you are just wasting gas on the far side of the power peak.
				Mgalutia88
anything above 8k rpm is equivelant and about as useful as a clutch that's slipping
				piolob
- Color: red
sendler2112 wrote:A stiffer contra spring will raise the pulling rpm. So will lighter weights. They balance each other. But the weights do it without the draw back of smashing your belt. 8,000 rpm should be the fastest setting for a stock engine. Anything higher than that is entering an area of lesser power again and you are just wasting gas on the far side of the power peak.
Now, with 8 gr rollers, I'm @8300 WOT and ,yes, it's too much (feeeling as something is slipping).Mgalutia88 wrote:anything above 8k rpm is equivelant and about as useful as a clutch that's slipping
Today I'll put 9gr rollers that should bring WOT @7900/8000rpm
				piolob
- Color: red
I got yuor PM, but I cannot reply.wojtek_pl wrote:Off topic a little: How do you check RPMs ?
Is it that PCX have speed limiter of some kind, built in ECU ?
 Write me another PM with your email, so I can answer your questions.
				piolob
- Color: red
sendler2112 wrote:You are not making enough power and you are not aerodynamic on the bike. Do you test for top sped by riding in a tuck? My USA PCX150 will redline at 9,600 rpm on my tach and 67 mph but only if I tuck and there is no head wind. Into a wind it may reach only 65 mph and 9,400 rpm. Your PCX125 has 2 hp less so you are stuck at a lower top speed by the wind. You are hitting a high top speed whem revving it on the center stand so the speed performance of your vario and belt is good. That is not the problem. It's just that you need more power. Which is not easy to do. Maddiedog put $1,000's of dollars of parts on his PCX and didn't really gain any top speed. It would be easier to trade the PCX on a bigger scooter.piolob wrote:But why cannot I reach rev limiter on the street?
I tried riding in a tuck in a short downhill: I got 118kpm@9000rpm, then I had to brake.
I have also put 8+9,5gr rolleres and now I get 7900rpm@WOT
				Mgalutia88
there you go!!!
				piolob
- Color: red
Mhhhh, riding in a tuck is not ideal in my opinionMgalutia88 wrote:there you go!!!
 I did some test:
Original vario:
WOT@6900
70kpm@6300
80kpm@7300
vel max (tuck) 108@9560
Malossi Vario with 14.7gr. rollers:
WOT@6300
70kpm@5800
80kpm@7150
vel max (tuck) 110@8000
Malossi Vario with 9gr. rollers:
WOT@7900
70kpm@6600
80kpm@6900
vel max (tuck) 118@8900
The original vario is 560gr
Malossi vario is 646gr
Could be the higher weight of the Malossi vario causing the motor not to get high rpm?
				wojtek_pl
- Year: 2014 PCX 125
- Color: matt black
This may be stupid question, but WHY do You want to go that fast on PCX 125 ? It's not built for speed anyway...
									Regards
Wojtek
2014 Honda PCX 125
						Wojtek
2014 Honda PCX 125
- sendler2112
- Year: 2013 PCX150
Increased mass will decrease acceleration of the rpm but won't affect top speed or rpm. It just takes a little longer to get there. Your issue is still the same. You don't have enough power to go through the wind any faster. It's not an rpm thing. It's the normal power curve of the engine dropping away above 8,000 versus the increasing wind resistance at that speed. For every doubling of the speed, the wind resistance increases by 4 times. At 118 kph your stock engined PCX125 is already one of the fastest around. You can try removing the snorkel in the air box and drilling the exhaust to see if that will give a few more tenths of a horsepower but it makes the bike really loud.piolob wrote:The original vario is 560gr
				piolob
- Color: red
I know it's not made for such a speed,wojtek_pl wrote:This may be stupid question, but WHY do You want to go that fast on PCX 125 ? It's not built for speed anyway...
but I'd like to have a little more speed, so when I ride with my wife I can go about 90/100 without being always @limit
And also because a lot of people is saying they are gettin 115/120, so I wanna know WHY my PCX is not able.
				piolob
- Color: red
sendler2112 wrote:Increased mass will decrease acceleration of the rpm but won't affect top speed or rpm. It just takes a little longer to get there. Your issue is still the same. You don't have enough power to go through the wind any faster. It's not an rpm thing. It's the normal power curve of the engine dropping away above 8,000 versus the increasing wind resistance at that speed. For every doubling of the speed, the wind resistance increases by 4 times. At 118 kph your stock engined PCX125 is already one of the fastest around. You can try removing the snorkel in the air box and drilling the exhaust to see if that will give a few more tenths of a horsepower but it makes the bike really loud.piolob wrote:The original vario is 560gr
Snorkel already removed, nice sound
 Drilling exaust is not for me.
So, should I be happy about 118 in tuck?
 I think you are right about wind resistence, this week should be avaible the Givi windshield, let's hope it will give me some aerodynamic advantage.
				pcx125
I had very similar setup to your on my PCX125 and I can get max speed is 120- 123km/hrs (on the road) . I don't go with that fast day to day, just try for testing after installed Malossi Variator. In my eyes this setup is perfect for me day to day ride in City, its quite good acceleration from traffic lights, and at corner turn
Please ask or look at Buddy1976 setup. This man guided me through step by step with all the parts and how to setup on my PCX125 . (thanks again Buddy1976)
Here are the parts I got for my PCX125
Variator (10.5 rollers)
http://www.pcxracing.com/product.php?id_product=109
and
Springs (Red)
http://www.sip-scootershop.com/en/produ ... r_m2912536
and
Springs (Red)
- sendler2112
- Year: 2013 PCX150
I heated and bent my Givi short windscreen back to get the best aerodynamics and best clearing of my face shield in the rain. Any bike with a windscreen that you can just peek over while crouching forward right behind the top edge will act like a blow drier which sheets the rain right off of your visor like magic any time you are going over 40mphhpiolob wrote:I think you are right about wind resistence, this week should be avaible the Givi windshield, let's hope it will give me some aerodynamic advantage.
https://fbcdn-sphotos-e-a.akamaihd.net/ ... 5888b3f434
				piolob
- Color: red
The setup is really good for acceleration, but my problem is top speed.pcx125 wrote:I had very similar setup to your on my PCX125 and I can get max speed is 120- 123km/hrs (on the road) . I don't go with that fast day to day, just try for testing after installed Malossi Variator. In my eyes this setup is perfect for me day to day ride in City, its quite good acceleration from traffic lights, and at corner turn
and
Springs (Red)
I found that lighter roller are even better for acceleration.
Clutch springs will give more start acceleration (I dont need now).
Also a stronger contra spring will give you better mid-range acceleration (40-90kpm) and better uphill speed.
I will write Buddy1976 PM
 Do you reach 120kpm riding normal or in a tuck?
				piolob
- Color: red
sendler2112 wrote:I heated and bent my Givi short windscreen back to get the best aerodynamics and best clearing of my face shield in the rain. Any bike with a windscreen that you can just peek over while crouching forward right behind the top edge will act like a blow drier which sheets the rain right off of your visor like magic any time you are going over 40mphhpiolob wrote:I think you are right about wind resistence, this week should be avaible the Givi windshield, let's hope it will give me some aerodynamic advantage.
Is it giving you any aerodynamic help?
- sendler2112
- Year: 2013 PCX150
Top speed in a tuck was about the same but riding in the rain is obviously much better with the windshield.piolob wrote:Is it giving you any aerodynamic help?
