Forza Rear Wheel Removal
Alibally
Re: Forza Rear Wheel Removal
Post by Alibally »
dergav wrote:dont think thats an answer to my query?
Get a couple from the Honda dealer mail order. I'm sure someone will do this.
http://www.lingshondaparts.com/honda_mo ... ock_05=hmc
Quick google search found this.
dergav
Color: grey
Post by dergav »
Alibally...thanks for that ..problem solved...couple ordered...for some reason I just never found through google what you provided...senilty thing I suspect...so thanks....
You can get them mail order from any Honda parts supplier.
Part number is 90305-KWN-701, £6.23 from here
Although changing them is recommended, I still have the original one on mine after 32,000 miles and many tyre and pad swaps.
dergav
Color: grey
Post by dergav »
great help boys...thanks
just reused the nut last tyre change but thought i should get new one this time...suppose reused nut properly tightened would suffice however...now to get wheel off...and check those brake pads!
Alibally
Post by Alibally »
The nut will probably be OK a few times. As long as its tightened correctly. With the number of wheel removals in a year for new pads you wouldn't want to buy a new nut every time anyways.
davenowherejones
Post by davenowherejones »
I checked the rear pads today. You do not need to take the wheel off to do this. Just pull the caliper off.
