Re: Broke my left leg, gear ideas?
Posted: Thu Aug 07, 2014 4:31 pm
Forget about the *gear* ride smarter or take the bus?
https://hondapcx.org/
UK part prices......Mgalutia88 wrote:New parts for are scoots are ungodly cheap. You could buy all the plastics on the bike prepainted for the cost of a gallon of the three stage paint. It's not cheap paint at all. In another example, I replaced and had both tires mounted for less than the cost of a gallon of the three stage red. Last front upper side panel I bought was $28 usd and the lower painted fairing was $15 usd.
How about you troll someone else's thread instead of adding insult to injury in the most literal sense asshole?you you wrote:Forget about the *gear* ride smarter or take the bus?
Yep, upper part of the fibula IIRC. I suppose it also looks like it could have been twisted. I've have to wait until my follow-up appointment sometime next week to get more details about exactly what happened.WhiteNoise wrote:Oh yeah, ya done good.... that's nasty! Feeling even worse for you now Valiant. But I have to say, you sound like you're doing pretty good under the circumstances, so I congratulate you for that.
Looking at your x-Ray, is that a second break on the upper right? Geez.
Sentenced to life in... HawaiiMel46 wrote:The good thing is that it will heal, maybe even as good as new. The bad part is that if you move to a climate that changes to extremes you will feel it in your leg. Stay in Hawaii and you will be fine.
Which makes sense. The protective gear doesn't prevent the accident, it just reduces the damage.katschamne wrote:I hope that you are feeling better Valiant. I see that I missed this posting. I have had a couple accidents and I have asked the same thing if more protective gear would have helped me and every answer has been no.
Okay, so isn't this kind of backwards with regards to criticizing gear? If you don't have impact armor, it shouldn't come as a shock that you have zero protection against breaking your bones. What little gear you did have did its job, you don't have road rash.In each of those times I've asked it gear would have helped and in each case the answer was no. I did have boots, gloves, leather jacket, jeans and a helmet. I only have a leather jacket because I can't find gear with armor to fit me, and believe me I have tried. The last two times the jacket was scuffed and I had minor scratches. My pants never ripped. The gear I had did protect me against road rash just not the broken bones. I would be riding today but it's in the shop getting an oil change and tune up.
This is why I generally like to keep enough distance between me and the car in front of me in case I need to stop in a hurry. I also generally give buses and other large vehicles a wide berth in case a car tries to cut right behind it.Each time I fall I look at it as what could I've done differently. It wasn't nearly as scary falling the last time in grass as it was looking at the back of car and knowing I wasn't going to be able to stop in time.
Yeah, I'd prefer to go without the metal rod stuck in my leg to hold the pieces together.Steph wrote:@Katschamne- I would like to recommend wearing armored Hi-Viz gear. Like in my profile picture. I now wear a fullface helmet and knee and shin protection now. Broken bones are a little harder to prevent even with armored gear. But, It helps.
Yep, I got screwedMel46 wrote:I don't think i have seen a break quite like those, and i was an X-ray tech during Viet Nam. How did you break it at the top AND the bottom at the same time?? It looks like you twisted your foot after the upper bonewas broken, thereby snapping the lower one while it was still in the boot. That is not a normal break, but it obviously happens. Did they have to put pins in it? I would expect so on the lower one.
The good thing is that it will heal, maybe even as good as new. The bad part is that if you move to a climate that changes to extremes you will feel it in your leg. Stay in Hawaii and you will be fine. Good luck in the future.
I think I'll managehomie wrote: Sentenced to life in... Hawaii
I wasn't criticizing gear, more to the point like you said it doesn't prevent an accident it might reduce the damage. I was was trying to say the armor gear is more for skids and not breakage. Just like the helmet I wear protects me against bugs, rocks and maybe in some crashes but if the accident is bad enough it won't save you. I believe in some kinds of gear even if it's minimal. You will never see me out there in shorts, flip flops (both of which is what I wear all the time when I'm not on two wheels) or without a helmet but I will admit I have ridden without gloves and a jacket in warmer weather. Although in the accident I kind of had road rash on my knee from my jeans. They didn't rip but it was like a really bad rug burn.Okay, so isn't this kind of backwards with regards to criticizing gear? If you don't have impact armor, it shouldn't come as a shock that you have zero protection against breaking your bones. What little gear you did have did its job, you don't have road rash.
I agree. Although in this case I was on the main road and she was pulling out of a parking lot. I saw her coming up to the stop sign pretty fast so I started to slowed down. She appeared to slowing as well until she rolled right though the stop sign. She didn't even look my way when she turned. If she hadn't turned wide I would have been able to go around her.This is why I generally like to keep enough distance between me and the car in front of me in case I need to stop in a hurry. I also generally give buses and other large vehicles a wide berth in case a car tries to cut right behind it.
Unfortunately none of the armor gear fits me. I am a large girl and even if I try men's gear it still doesn't fit.Steph wrote:@Katschamne- I would like to recommend wearing armored Hi-Viz gear. Like in my profile picture. I now wear a fullface helmet and knee and shin protection now. Broken bones are a little harder to prevent even with armored gear. But, It helps.
Abrasion resistant fabrics like leather, kevlar, and textiles are meant for "skids" and prevent road rash. Impact absorbing armor is meant to provide some protection for your bones.katschamne wrote: I wasn't criticizing gear, more to the point like you said it doesn't prevent an accident it might reduce the damage. I was was trying to say the armor gear is more for skids and not breakage.
Nobody expects perfection. It's the brain that decides whether you hit that car at 60 mph, at 40 mph, or not at all.Just like the helmet I wear protects me against bugs, rocks and maybe in some crashes but if the accident is bad enough it won't save you.
In my experience with bicycling, jeans IMO don't provide any better protection than any other fabric.I believe in some kinds of gear even if it's minimal. You will never see me out there in shorts, flip flops (both of which is what I wear all the time when I'm not on two wheels) or without a helmet but I will admit I have ridden without gloves and a jacket in warmer weather. Although in the accident I kind of had road rash on my knee from my jeans. They didn't rip but it was like a really bad rug burn.
If price is no object, have it custom made:Unfortunately none of the armor gear fits me. I am a large girl and even if I try men's gear it still doesn't fit.
