Re: speedometer and odometer stopped working.
Posted: Sat Mar 08, 2014 10:59 pm
Hey Mel, I just remembered that maddiedog provided us with the PCX wiring diagram
it's right here: http://www.hondapcx.org/viewtopic.php?f=15&t=771
https://hondapcx.org/
No reason apart from the fact that that fault coincided with a refuel. Also as the digital display also no longer displays fuel levelMel46 wrote:How does the fuel sensor affect the speedometer and odometer? I havent followed the diagram all the way through yet, but it would seem to me that you should at least be able to see your old mileage on the odometer.
If it is the dash then I will be saving up for the kitico one :-)iceman wrote:The 2011-13 123 dash is £65 on Ebay - then there is the nice electronic alternative
fungomerry wrote:Local dealer says that it wont be fixed under warranty as I have missed to services. He wanted £80 just to have a look at the problem :-(
Is Webike the cheapest site to pick up the Kitaco speedo at £225 inc shipping to the UK?
Damn, that is depressing as I have no idea how to go about checking that :-(rebrab842 wrote:Its a broken wire somewhere on the loom. I had this problem fixed under warranty so don't know a lot about it.Its something to do with the suspension going up and down and rubbing through the wire .
Although you may be able to spot where the problem is by removing panels, a better way to check end-end continuity is to remove the battery (don't want any shorts!) and with panels removed, check using the ohm (resistance measurement) on a meter one end to other - if the wiring loom and diagram makes sense. May be a lot of work not knowing where things are routed, but once found, you may be able to lay a new wire in for next to nothing.fungomerry wrote:Damn, that is depressing as I have no idea how to go about checking that :-(rebrab842 wrote:Its a broken wire somewhere on the loom. I had this problem fixed under warranty so don't know a lot about it.Its something to do with the suspension going up and down and rubbing through the wire .
Can I check the current with a voltmeter where the loom plugs into the dashboard?
Although you may be able to spot where the problem is by removing panels, a better way to check end-end continuity is to remove the battery (don't want any shorts!) and with panels removed, check using the ohm (resistance measurement) on a meter one end to other - if the wiring loom and diagram makes sense. May be a lot of work not knowing where things are routed, but once found, you may be able to lay a new wire in for next to nothing. Thanks fungomerry, useful to know this - without 'something' reaching the dash, it acts dumb and shows nothing rather than zero or such.fungomerry wrote:Damn, that is depressing as I have no idea how to go about checking that :-(rebrab842 wrote:Its a broken wire somewhere on the loom. I had this problem fixed under warranty so don't know a lot about it.Its something to do with the suspension going up and down and rubbing through the wire .
