Depends on the machine, some are a lot worse than others, my preference for a 700 parallel twin would be a 360 crank.sendler2112 wrote: 180 cranks buzz worse.
The problem is that Honda deliberately made the NC/CTX engine vibrate, this is on the record, you will find this on Honda's website.
Single cylinder engines also vibrate but ride a Forza.
Once under way there is no vibration whatsoever at normal speeds.
This is because Honda chose to eliminate vibration.
And that's why I hate the NC/CTX motor, it could be made to vibrate less.
NVH, read up on it.
