@ grndslm, pm sent to you.
Acceleration test
Re: Acceleration test
(Excuse me a moment folks for going off topic. Thanks
grndslm
Anybody?grndslm wrote:I tried using the app... Set it for 0 to 40 mph.. Hit start twice... Locked into GPS... Ready... GO!!
Then I get to 60 mph and nothing happens. No "races" stored in the history. Nada. What am I doing wrong?
- Rickjds
- Year: 2020
- Color: Candy Luster Re
Bone stock 2020 PCX150
- CABFE39D-E5EA-42B2-88C8-0B4FD56EE49A.jpeg (119.13 KiB) Viewed 13771 times
That is a VERY smooth acceleration curve. Its pretty cool to be able to compare acceleration curves. Thanks for sharing.Rickjds wrote:Bone stock 2020 PCX150
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
Uninstall and reinstall app?grndslm wrote:Anybody?grndslm wrote:I tried using the app... Set it for 0 to 40 mph.. Hit start twice... Locked into GPS... Ready... GO!!
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
grndslm
NCY drive face + variator + 13 gr rollers + aftermarket clutch bell...
It *feels* faster than this to me. Pretty sure it's GPS lab most of the time (this is my best time. I have gotten up to 6.9 second, with most being around 6.4... but then again, it also depends on the time. wonder if a different phone would help. hmm...)
grndslm
Here we go!!
Was trying to edit and add the image but had to resize on my phone..
- 0_image (1).png (114.63 KiB) Viewed 13745 times
Morning Cool fresh air helped this morning. Best time to date. Wonder if my open CVT helps keep everything cool and happy
grndslm, What bell you running?
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
grndslm
I've got 2 bikes. Original 2013 is still in the shop right now, not this newer 2015 has this bell --> https://theruckshop.com/product/perform ... -12-spoke/
I thought it had a checkered grip, but it's actually just grooves that loop the entire inside diameter. I guess it's better than stock, but I would much rather prefer a sandpaper or checkered texture. The OG 2013 PCX of mine has this one, which I was unable to find in stock (or even anything remotely similar for under $100!) --> https://www.ebay.com/itm/KAO-GY6-125-15 ... 3337103123
Seems to be the best texture, IMHO... yet now unobtainable. :-/
I think that ground slope and wind speed / direction probly account for almost as much variance as most of these aftermarket parts are creating. Should get my 2013 back within a week and will see if I'm able to detect any differences. If anything, I'd expect the 2013 to be a tad slower at accelerating, considering it's geared just a tad higher.
- Gil
vamootsman wrote:I have no idea. Maybe the app malfunctioned. Guess I'll have to go do it a few more times. I did it after about 5 minutes of riding so I know the belt wasn't very hot. Felt like the front wheel was going to come off the ground. Could be a fluke, or luck, or just perfect timing. Don't know for sure, but it felt really awesome.
When I had my stock clutch bell, I would slingshot out of every stoplight. The stock clutch pads are quite aggressive and will engage at a higher RPM, when they don't chatter that is. Now that I have changed the clutch bell to one with a textured surface, my scooter won't slingshot from a stop anymore. It's a more delayed smooth clutch engagement. Great for leisurely riding, not so much for "drag" racing. I might need a more aggressive clutch pads.
This is the clutch bell that I installed. https://japan.webike.net/products/24136 ... view-block
- b_5.jpg (122.16 KiB) Viewed 13654 times
- Gil
I couldn't remember the App that we were using on this thread, so I used a different one. It feels like the aluch performance has improved a bit. The best one was 5.7 s to 40mph, but it didn't save. I think I might be getting lausi GPS signal, that's the only thing that can explain the dips in the graph. I'll go out tomorrow and find a nice flat road to do some repeated runs with the original app.
- Screenshot_20201202-200252 (4).png (45.31 KiB) Viewed 13653 times
- Screenshot_20201202-200252 (3).png (82.98 KiB) Viewed 13653 times
- Gil
I'm not too far from you guys. I'm gonna try stiffer clutch springs. At launch my scoots RPM drops considerably when the clutch engages. I think I could gain a second.
- Screenshot_20201205-001611.png (97.65 KiB) Viewed 13650 times
Let us know which springs you change over too. Curious how much it helps acceleration.Gil wrote:I'm not too far from you guys. I'm gonna try stiffer clutch springs. At launch my scoots RPM drops considerably when the clutch engages. I think I could gain a second.
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
grndslm
What app is that?Gil wrote:I couldn't remember the App that we were using on this thread, so I used a different one. It feels like the aluch performance has improved a bit. The best one was 5.7 s to 40mph, but it didn't save. I think I might be getting lausi GPS signal, that's the only thing that can explain the dips in the graph. I'll go out tomorrow and find a nice flat road to do some repeated runs with the original app.
- Gil
Drag Race is the one with the dark background. The app I couldn't remember the name off is TRC.
- TRC app
- trc.PNG (110.9 KiB) Viewed 13633 times
- Drag Race app
- dragrace.PNG (139.66 KiB) Viewed 13633 times
- Rickjds
- Year: 2020
Bone stock other than a Malossi exhaust. Compare to previous times with stock exhaust. At least I can see an improvement.
- F7827549-4367-44C5-8D49-11FBB4D3EB83.png (393.26 KiB) Viewed 13536 times
I am not even going to attempt this, but my 2013 with NCY variator, drive face, and weights gives me a max speed of 75 mph, though I have 13 gm weights which will not be the fastest takeoff weights. I think those would be 11 gm.
My objective was more top end, not how fast I could get there.
If you tune the CVT correctly, you can obtain great acceleration, and retain top end speed.
The goal is to go as light as possible with the weights but heavy enough to get full Variator travel. Allowing the belt to fully travel, instead of it jumping all the way up on the variator and causing heavy wear on specific parts of the Variator and Driveface.
If you run too heavy of weights, its like jumping to Overdrive and keeping the RPMs too low to get into the powerband.
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
- vamootsman
OK OK enough is enough. No one on this forum has a PCX 150 that will consistently run 75mph without a displacement upgrade. Downhill doesn't count. Tailwind,,,great but doesn't count. Alice went down that rabbit hole and Physics filled it in and she's lost. Stop the madness!Conelite wrote: ↑Sun May 23, 2021 10:47 amIf you tune the CVT correctly, you can obtain great acceleration, and retain top end speed.
2013 PCX 150 with,
2005 Piaggio X9 500 Evolution
1982 Honda CX500 Turbo
1983 Honda Nighthawk S
Consistent "cruising" at 75 no. But being able to hit 75 tucking (Stock windshield) is not that difficult. lolvamootsman wrote: ↑Thu Jun 17, 2021 9:55 pm
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
