Weather report
trigg123
Re: Weather report
Post by trigg123 »
Woolley
I would def invest in a trickle charger,it monitors the battery and "trickles" as it needs it......starting it isnt enuff it needs to be ridden to charge properly....its easy to fix the lead to the battery and will be the best 50ish quid youll spend on the bike!!
cheers Buddy
Trigg :D
TC3
Re: Weather report
Post by TC3 »
I totally agree with that. Optimate 4 is a good un I got for the pcx recently
Re: Weather report
Yeah, definitely avoid the ice. The only time I've ever laid down a bike, I had to lay down my nearly half-ton PC800 on black ice to prevent bouncing off cars going down a hill. o_O
Be sure to put some fuel stabilizer in your tank, I prefer Sta-bil or Seafoam...
Woolley
Weather report
Post by Woolley »
I would, but I don't have £50 spare after buying a car, in fact I still have £2500 to pay on credit cards :(
0% until November but I just want them outta the way.
ImageImage ImageImage Image
Re: Weather report
Seafoam should only cost a couple £, and will save you quite a bit if your injectors get clogged from gas getting gunked up... I totally understand though, debt sucks. :(
Woolley
Re: Weather report
Post by Woolley »
Yeah ill get some seafoam or stabil, is it best for the tank to be completely full of petrol? And how much of the stuff do i put in?
Woolley
Re: Weather report
Post by Woolley »
And yes debt does suck but without it i wouldnt have had a PCX :)
Re: Weather report
Full tank, follow the instructions on the bottle. It's just a little splash for a tank as small as the PCX's.
edscoot
Re: Weather report
Post by edscoot »
9.20am Sunday 4th Dec, Carlisle, Cumbria, UK. It's started snowing :cry:
I guess this means that the roads will start being gritted now. So I'm going to have to spend today taking the panels off the scoot and waxoyling the frame. And I'm definitely going to get the exhaust powder coated. I'll take some pics and post them when I can.
Does anybody have a recommendation for a clear lacquer that is heat resistant for my swing arm?
Alibally
Weather report
Post by Alibally »
Woolley wrote:I would, but I don't have £50 spare after buying a car, in fact I still have £2500 to pay on credit cards :(
Check this then.
http://www.busters-accessories.co.uk/pr ... ger-291111
trigg123
Re: Weather report
Post by trigg123 »
Ed
im pretty sure you cant powder coat an exhaust, i wanted my dylan one doing a while back they said it cant be done because of the temp,,,,,,,i ended up using hammerite bbq paint which works but if you want to keep it looking good youll have to do it every 9 months or when its looks tatty
regards Trigg
EddieC
Re: Weather report
Post by EddieC »
BBQ paint works great! Its made to be able to take the heat and expansion of the metal. I haven't used it myself, but I've seen a bunch of people paint their exhaust with it.
Woolley
Re: Weather report
Post by Woolley »
Check this then.
Will one that cheap actually do the job?
Alibally
Weather report
Post by Alibally »
Support you get what you pay for but if it's sold as a charger then it's got to be better then nothing. Google it and see if there any reviews.
EddieC
Re: Weather report
Post by EddieC »
ya it'll probably work fine while its new... Its more of a longevity issue when it comes to cheaper electronics IMO. If you use it indoors it'll probably last longer
Woolley
Re: Weather report
Post by Woolley »
i keep my PCX in the garage so shouldnt be a problem. Ill have a good trawl through the internet and ill probably buy it tomorrow as i get paid then. Thanks for the recommendation Alibally.
Woolley
Re: Weather report
Post by Woolley »
Struggling to find sta-bil or seafoam. Think there not so well known in the UK. Will this do?
http://www.ebay.co.uk/itm/BRIGGS-STRATT ... 53e9a73a7e
Re: Weather report
Looks like it will, it says for four-stroke.
TC3
Re: Weather report
Post by TC3 »
Hey Woolley that is the exact charger I had for 6 years. Works very well and used each winter so should last. I sold it along with my bike earlier this year as I wanted something else. You can not go wrong with it.
Woolley
Re: Weather report
Post by Woolley »
Thats all i need to know then TC3, Ive just bought that and the fuel stabilizer i put a link to. Bring it on winter you icy bitch!
Did you leave the charger plugged in all winter then? And this might be a dumb question but do i need to take the battery out of the bike?
