Tuning the Forza 300 CVT
Re: Tuning the Forza 300 CVT
beautiful!
mario 18 years old .....without cosmetic sourgery ;.)
Mario remember bardhal oil next time.. waiting for your air filter test
r
what you need to open the variator 14 ? , and the torque is 84 to close? I have to change rollers
r
- Mario
New faster setup!!
16g Dr,Pulley sliders / DNA Airfilter / TechPulley x2 clutch - black CS springs - white PS springs
0-100 / 40-60 / 60-80 / 80-100km/h
Max speed
Max speed
May the Forza be with you!!
ciao mario
16 dr pulley? why you change?
Did you find difference in the new air filter?
Robert
Robert
- Mario
Hi Robert,robertinino wrote:ciao mario
Robert
I'd did the filter and the 16g DP in one change so don't know the individual improvement, but again it's a little faster now 0-100 in 9.6 sec without loosing end speed.
Next thing will be a Arrow Reflex 2.0 with race header, the muffler air filter combo will hopefully bring the Forza under the 9sec.
Greetings, Mario
- sendler2112
- Year: 2013 PCX150
Very nice testing. The 40-60-80-100 runs really let us see the action of the trans. That is getting pretty radical with the 6,000+ rpm clutch engagement and 7,600 pulling rpm of the 16gm sliders which are still slightly active above 100 kph. Does the clutch feel disconnected and jumpy between coasting and catching when driving around at parking lot speeds?
It is also interesting to see that with the light sliders of either 18gm or 16gm and the heavier contra spring, the 400 rpm creep during the shifting phase that the original poster had gone to such great lengths to eliminate with his mix'n match set up is gone from your bike as well.
- Mario
All actions are smooth with the new clutch, only thing is that the clutch with easy low throttling gomes in from 4000rpm and above, but that's OK by me.
- sendler2112
- Year: 2013 PCX150
4,000 is good. It looked like 6,000 on the videos but some of that must be attributed to the low gearing that the sliders provide instaed of rollers. And the lower weight of the 18gm or the 16 gm.
- Mario
When I hit the throttle full from start it go's direct to 6500rpm and slowly rises to +7000 till the end of the variator range, very smooth but powerful transition!!
Btw, all testing is with sitting upright and flat roads.
Video of the low throttle respons.
- Year: 2023 XMax 300
- Color: Grey and black
Hello again.....soory for the delayed response but I've been on the road for a few weeks.
Mario, you started modding your Forza at 300Km.....
I waited until 2000miles before going to lighter weights.
in fact I actually ran heavier weights briefly before I started really going light on weights just to "exercise" the variator and flex the contra.
Here's why:
above are two IDENTICAL springs, both Honda OEM contras...
one has 7500 miles and one is new.
The engine is the least of your worries.
Most of the break in is for everything else on the scoot!
you side stepped the normal contra wear in by installing a lighter contra.
I think that's why the combo didn't work for you....it would have in time.
As for "great lengths" mentioned by Sendler.....
if you remember I started this thread about tuning the OEM variator.
Everything on my drivetrain is completely stock except the variator weights.
The total cost was about $60.
The result is my Forza will do 0-75 in <15 seconds, which was the Forza's stock 0-60 time.
It still gets 68mpg and I trust it implicitly on the Interstate at 80mph.
I realize the exotic aftermarket stuff is cooler than tuned stock but it all depends on your intended purpose (and your purse!)
Here's why:
hi bred how are you? after long time I see you again.
Mario tested what you suggested mix rollers- sliders with bad results!! why??
May be this is the reason why he decided to test other solutions...
Robert
Robert
Robert, it takes a few miles for some components to reach their optimum tolerance.
The springs start off a about 110% of the desired long term strength.
the heavier the spring the more weight required to compress it at any given rpm.
patience, Grasshopper!
I want to know how is the time 0-100 km with these set up:
1 Mario set up: 16g Dr,Pulley sliders / DNA firfilter / TechPulley x2 clutch - black CS springs - white PS springs
2 Bred set up : 3x20 grams Dr Pulley and 3x16 grams rollers
.Vulcandanny (in this topic)............ 6 x17 grams dr pulley 0-100 km 9,81 seconds
thank you
Robert
thank you
Robert
- Mario
When I hit 2000 miles I probably have a Integra 750BRed wrote:Hello again.....soory for the delayed response but I've been on the road for a few weeks.
Here's why:
My gain is a more sporty than standard Forza, at the moment my Forza use about 1-26 km fuel and that ok by me.
Robert, my Forza running mixed weights will do 0-100kmph (60mph) in 10 seconds...probably a little less.
Bred what do you think about:
flyng tech pulley are better than dr pulley?
and autisia variator is better than j costa? https://www.youtube.com/watch?v=MHwyB9ZZxys
thank you
R
thank you
R
- sendler2112
- Year: 2013 PCX150
No need to change the variator on the Forza. All that is really needed to make a big performance gain are some 18 or 16 gm sliders for $30.
- Year: 18 300 xmax
You certainly are knowledgeable about this.....could you start (or point me) another thread on exactly what the rollers/sliders do? Why are sliders better? Or are they? Downside vs rollers?sendler2112 wrote:No need to change the variator on the Forza. All that is really needed to make a big performance gain are some 18 or 16 gm sliders for $30.
Based on yours and a few other threads i replaced my rollers with 13 g sliders and got a substantial increase in take off torque and speed, exactly what i was looking for. But i dont think ive read a "why" this is happening.
Thank you.
‘15 PCX build thread here:
